Post by Eyrey1 on Oct 28, 2013 16:13:03 GMT 1
does this one go on the top casing where the wire from the stator comes out ?
Post by winnerevo1 on Oct 28, 2013 16:53:40 GMT 1
First one is an oil pipe clip/guide to tidy up the oil pipes from the pump up to the carbs, secures behind one of the screws that holds the R/H clutch cover/casing on.
Second one holds the clutch actuator lever in the top of the crankcase in place.
Post by Eyrey1 on Oct 28, 2013 18:05:26 GMT 1
the second one is to stop it coming out ! thank you it was doing my head in ! got this far and dont want bits left over lol
Post by Delbert on Oct 31, 2013 7:58:19 GMT 1
Looks cracking mate , nice job !!
phil38
Post by phil38 on Nov 6, 2013 21:02:03 GMT 1
Second one goes here (on the left)
Post by Eyrey1 on Nov 6, 2013 21:11:47 GMT 1
cant see anything on the left do you mean the 2 stroke pipes on the right ?
Post by Yogi on Nov 6, 2013 21:36:42 GMT 1
It bolts just below the clutch arm on left top below the left reed block and holds the clutch arm down in place
Post by Yogi on Nov 6, 2013 21:49:27 GMT 1
If you look below the red bung where phials left carb goes you'll see it in place, one small bolt holds it in place,, I took a pic of mine but can't upload it and can't work photo bucket,,too old
Post by Eyrey1 on Nov 6, 2013 22:02:27 GMT 1
ok cheers sorted thanks
