Post by kostas on Oct 20, 2013 8:29:16 GMT 1
I need to remove the paint from the fairings, so I can have those redone. Seems these have been painted over at least once, so I would like to completely remove the paint.
What do I use? Paint remover or just sand it down. Will paint remover damage the ABS plastics?
Thanks Kostas
Post by Shytalk on Oct 20, 2013 9:05:57 GMT 1
Kostas Do NOT use paint remover or heat gun to remove the old paint - you will damage / destroy the plastic. You will need to sand it off.
Post by kostas on Oct 20, 2013 17:34:56 GMT 1
I guess paint remover is out of e question then
Thanks
m1ke
Post by m1ke on Oct 20, 2013 20:15:50 GMT 1
I believe there are paint removers designed for use with plastic out there, but they may not be quite as good as normal ones.
morph
Live life according to a dogs philosophy.If u can't f@&k it or eat it piss on it and walk away.
Post by morph on Oct 21, 2013 9:24:30 GMT 1
Hi sanding is the way to go .My paint on my bikini fairing hadn't bonded with plastic and was flaking managed to get most of it off by using the edge of one of those cardboard box knives .HTH
Post by shane250 on Oct 26, 2013 9:40:03 GMT 1
Brake fluid.
Post by kostas on Oct 26, 2013 17:37:35 GMT 1
Wow brake fluid?? Would have never figured this out myself!!
