rdleigh55
Newbe
bikes. rd400c, rd350ypvsf2, xj600 s diversion,cb600 hornet
Post by rdleigh55 on Oct 18, 2013 15:31:48 GMT 1
hi,my fuel tap lets fuel out in the res and on position without the engine running,i have done a tap overhaul with parts from norbo but still the same,what else could it be?? ,the fuel comes out of carbs overflow pipes quite rapidly,am i right in saying fuel should not leave the tap unless engine is running as it is a vacuum type system.the carbs have been done to spec float heights ect!!!.any help appreciated.cheers leigh
Post by Shytalk on Oct 18, 2013 16:32:26 GMT 1
I don't think the F2 uses a vacuum system... either way if fuel is coming out of the overflow pipes on the carbs then the float valves aren't sealing, the rubber O ring will be perished.
rdleigh55
Newbe
Post by rdleigh55 on Oct 18, 2013 16:46:29 GMT 1
if its not vacuum type. why is there not a off position on the fuel tap.only prime,reserve and on
Post by Denzil on Oct 18, 2013 16:55:51 GMT 1
It does use a vaccum system. The small opening is for the pipe that attaches to it and then to the opening on the right hand carb. As said there is no off position because it is under vaccum pressure.
loop
Post by loop on Oct 18, 2013 17:24:52 GMT 1
I had exactly the same problem after I rebuilt the tap on my F2. I stripped it down again, in there was still some dirt (old o ring) in the seating. Wrapped a pencil in a cloth & thoroughly clean it, now works fine.
By rights, fuel shouldn't come out the carb overflows, sound like dirt on the float valve seats as well. Like Shy says, if you take the seats out the o rings fall apart.
Good luck, let us know how you get on.
rdleigh55
Newbe
Post by rdleigh55 on Oct 19, 2013 20:30:17 GMT 1
thanks for help guys ,have another play with it tomorrow.let you know if i solve it
rdleigh55
Newbe
Post by rdleigh55 on Oct 20, 2013 14:22:42 GMT 1
hi,sorted the tap leak.the plastic part that separates the diaphragm has a very small hole that was blocked.seems to be working how it should and the bikes running great ,even got a quick blast on it
