Post by martyngsxr1 on Oct 17, 2013 20:46:26 GMT 1
Okay got a leak on my fuel tap now the fuel outlet on the tap shouldn't just pop out of the main body of the tap should it
Post by Shytalk on Oct 18, 2013 16:35:32 GMT 1
No it shouldn't BUT it is only a push fit TBH so if its had someone twisting it in the past it will pop off easily, you might get away with taking it off and wrapping some PTFE tape around it and popping it back in, if not you'll need another tap assembly.
