Post by robin on Oct 17, 2013 18:29:31 GMT 1
Just buggered my speedo reed switch, so my indicators have stopped self cancelling, anyone had any luck in replacing the little reed switch?
any idea where to get a replacement what type it is?
Post by thehut on Oct 17, 2013 22:02:31 GMT 1
i wondered what that was and how it works myself
Post by cb250g5 on Oct 17, 2013 22:36:13 GMT 1
Post by robin on Oct 18, 2013 10:23:05 GMT 1
cb250g5 Thanks for that information and the link, I have changed a few in my time too, I was just asking if anyone knew an exact part number so I could match current and volts. The link you sent is spot on for size, 20.5mm x 2.7mm
I Have just been to my local Maplin store, their part No. N30AD (£1.70ish) is close enough to the physical size for the job, it has to fit inside the holder, soldered in place and ticking away like a good'un when I spin the front wheel.
Next time I work on the speedo, I will pull the reed switch out trying to keep it level and square as it pulls out of the housing, I managed to flex the holder and cracked the glass envelope, that's why it stopped working.
Many thanks for the replies.
Robin
Post by rich on Nov 7, 2013 17:54:47 GMT 1
Robin, did you get hold of a switch? Just asking as I found one in my box of old bits of loom and would gladly pop it in the post if it helps
Post by robin on Nov 7, 2013 20:01:49 GMT 1
Robin, did you get hold of a switch? Just asking as I found one in my box of old bits of loom and would gladly pop it in the post if it helps Thanks for the offer Rich, but all sorted with the part from Maplins, works fine now...
