crank
Oct 16, 2013 20:03:55 GMT 1
Post by 65 on Oct 16, 2013 20:03:55 GMT 1
Hello Have a crank which has run 16000 km ... it has a high tolerance. Should I get it re-build or buy a new one.
the crank you can buy from rdlccrazy which brand it is, and the quality as on a Wiseco or banshee?
thanks for the help ron
crank
Oct 16, 2013 20:10:46 GMT 1
Post by marsbar350 on Oct 16, 2013 20:10:46 GMT 1
welcome ron norbo sells cranks built with japan quality parts so they are very good is yours that bad?
get your oil pump refurbished by arrow as the new crank might be in vain
crank
Oct 17, 2013 11:19:33 GMT 1
Post by 65 on Oct 17, 2013 11:19:33 GMT 1
Hi Again
No ... it is for service and being looked after, being replaced some washers. maybe I sell it, if I can find a new in good quality. There's a lot on ebay, can you / others recommend some places where I could look?
regards ron
crank
Oct 17, 2013 11:31:12 GMT 1
Post by Norbo on Oct 17, 2013 11:31:12 GMT 1
well I have them on the shelf £220 plus post exchange I only use race quality jap parts
phil38
crank
Oct 17, 2013 12:25:36 GMT 1
Post by phil38 on Oct 17, 2013 12:25:36 GMT 1
If the crank is within spec when you measure it (which needs to be done properly), it should be fine to keep using. 16,000km is nothing for a crank, assuming it's been fed with oil.
crank
Oct 17, 2013 13:59:17 GMT 1
Post by 65 on Oct 17, 2013 13:59:17 GMT 1
Thanks for the replies Will look at the crank when I get it back. Norbo .. I need to buy parts from you when I need to assemble the engine, maybe I order a crank. how will you measure it? as here froggy.se/skalmanmc//rd350/mech/crank/index.htmron denmark
