Post by Deleted on Oct 16, 2013 10:20:31 GMT 1
sure I have seen a list on here of (claimed) bhp output from the different ypvs engines but cant find it now, anybody have it?
Post by Deleted on Oct 16, 2013 10:50:21 GMT 1
cheers headcoats, had a read and brakes excellent? mst have been used to a fs1e, chart I am on about just gives power output for 31k engine through to 1wt
Post by muttsnuts on Oct 16, 2013 17:25:41 GMT 1
Post by rich on Oct 16, 2013 17:27:23 GMT 1
F2 was rated at 63 bhp by Yamaha, 31K models were 59. Bear in mind that these figures are 'at the crank'. On a dyno, you're more likely to see anywhere between 45 and 50 or low 50's for a good one
Post by hollo on Oct 17, 2013 23:17:47 GMT 1
My Mito fitted with a 31k engine gave 53.5hp at the rear wheel on the Dyno if that's any help to you . It's running Mircon GP pipes and pod airfilters ( no room for an airbox ).
Mike .
Post by bare on Oct 18, 2013 3:43:57 GMT 1
Dyno 'brand/type' used to produce those HP is a BIG factor. Eddy brake type dynos give dramatically lower HP numbers than those printed out by the Long proven to be poor; Dyno -jet contraptions.
Post by Norbo on Oct 18, 2013 8:03:02 GMT 1
As bare says . different make of dyno give deferent BHP readings . you may get 58 and your mate may get 63 but in realety yours has more power its down to the machine being used and how its set up .
