morph
Live life according to a dogs philosophy.If u can't f@&k it or eat it piss on it and walk away.
Post by morph on Oct 14, 2013 1:06:02 GMT 1
Hi has anyone done a list of compatable parts for a rd400e .Looking at Lc's a few parts look similiar eg rear footrests , neutral switch, airbox to carb clamps,cdi .TIA
Post by dusty350 on Oct 14, 2013 7:19:27 GMT 1
Hi I just compare parts numbers between bikes using the fiches I have downloaded off the net. Some engine parts share the same part numbers between the Lc and aircooled Rd's, but not many really. Having said that, I had a 400 engine with an Lc clutch fitted which had a different part number, so forum members experience is probably the best resource of what fits and what doesn't.
Dusty
Post by Norbo on Oct 15, 2013 8:32:03 GMT 1
There are a lot of parts that are almost the same and will fit front and rear fot pegs switch gear carb and air box clips all the engine seals except the crank and they are the same on the E&F model its only the stator side that's not the sme on the others . wheel bearings clutch plats the list gos on .
morph
Post by morph on Oct 16, 2013 1:26:09 GMT 1
Ok thanks guys so there are a few parts just thought somebody may have done it already and made a sticky Just me being lazy So will start Please feel free to add or subtract 1/ clutch parts 2/rear footpegs 3/neutral switch 4/switchgear 5/side cover rubber grommets 6/ wheel bearings 7/ speedo drive?
morph
Post by morph on Oct 16, 2013 1:27:17 GMT 1
Oh I forgot all available from Norbos shop
Post by muttsnuts on Oct 16, 2013 17:46:19 GMT 1
Regulator IS the same CDI is NOT the same, but I think an LC one would work on a RD400E/F, but have never tried it Stator IS the same, connection plugs are different ! Flywheel will fit and work, but is different to an LC one Clutch cable will fit Speedo cable will fit Tacho cable WILL fit Throttle cable will NOT fit Speedo drive will NOT fit (different diameter for wheel spindle) Front wheel bearings are NOT the same (different spindle diameter) Chain and sprockets WILL fit, but why bother ? Oil pump and drive WILL fit as a complete unit, but it has a slightly different ratio/pump rate, but will work ok Primary gears WILL fit (crank gear and clutch gear as a matched pair) Pistons WILL fit ! (64mm bore) Cranks will NOT fit Gearbox bearings, some of the LC bearings are the same, I have a list somewhere Gears, some of them are the same, again I have a list somewhere Forks will NOT fit, unless you do the whole yolks etc as well, the head stock is the same length so they are a straight swap in that respect Coils will NOT fit, but would work if you could fit them ! Wiring loom is different Headlight is different, but would fit with some fiddling Brake discs will fit, but 400 ones are 7mm and LC ones are 5mm, but they do fit directly between the models
Think that's about if it from me for now, I'll have to think about the rest of the bits
HTH
morph
Post by morph on Oct 17, 2013 8:12:44 GMT 1
Wow thanks for that really appreciate it you r the mutts nuts will add a pic of the bike thanks so far guys.
Post by Norbo on Oct 17, 2013 8:20:59 GMT 1
HT coil will all so work on the E/F models .
morph
Post by morph on Oct 17, 2013 8:28:11 GMT 1
HT coil will all so work on the E/F models . Cheers Norbo will b after some more parts off u soon.
Post by muttsnuts on Oct 18, 2013 9:57:49 GMT 1
BTW, just clarify about the stator, what I should have siad above is that the coils and pick up are identical, the backing/mounting plate isn't, so you need to swap them over, but that's a 2 minute job. The RD400 only has 2 slots in the backing plate, the LC has 3
HTH
