higgsy
Post by higgsy on Oct 13, 2013 21:57:29 GMT 1
Are the the same? I have a set that I'm going to use on the 275 racer, I have to keep the stock carb sizes. Also can anybody give me a base jetting setting using ram air pod filters please, and is it worth using the spacers to move the pods away from the carbs?
Cheers
Higs
Post by rich on Oct 13, 2013 22:50:46 GMT 1
Not identical but all the important bits - needles, needle jets and air jet etc are the same. It's almost like the 31K carbs were a refinement of the 4L0 ones. You won't need spacer tubes with Ramairs, they are only needed with metal backed K&N type filters where you get reflected pulses and this doesn't happen with foam. I would guess at something like 200 mains as a start.
higgsy
Post by higgsy on Oct 14, 2013 4:55:33 GMT 1
Cheers Rich, just trying to save myself some time! :-)
