Post by martyngsxr1 on Oct 11, 2013 19:40:13 GMT 1
Okay I've got the carbs apart and can't remember which one is the choke slide on one of the slides it has 2 cutouts and I'm thinking this is the choke slide am I correct
Post by Tone on Oct 11, 2013 19:53:18 GMT 1
If you mean the two cutouts on the top of the slide at the front and back then yes that one goes on the choke knob side i.e LH carb which should mean the cutaway at the bottom of the slide faces at the back towards the airbox side.
Tone
Post by martyngsxr1 on Oct 11, 2013 20:32:03 GMT 1
Yes that what I thought thanks for confirming
Post by billyboy on Oct 12, 2013 17:25:20 GMT 1
you got any nearer with the problem ?
Post by martyngsxr1 on Oct 12, 2013 19:33:32 GMT 1
Not really just rebuilding the carbs for a3rd time as there was so much shit in there and going to try a replacement cdi
Post by billyboy on Oct 12, 2013 22:21:49 GMT 1
have you cleaned the emulsion tubes ? dont forget to make sure the o rings are sealing ok around the needle bodies
Post by martyngsxr1 on Oct 12, 2013 22:30:13 GMT 1
There out at the moment in soak arsee speak
