Post by copper99 on Oct 9, 2013 8:47:49 GMT 1
Post by winnerevo1 on Oct 9, 2013 8:59:19 GMT 1
I just use the centre stand if I want to take the front or back end off.
Post by oldelsieboy on Oct 9, 2013 9:40:20 GMT 1
Dont see a problem with using this type, but you will only need one of them LOL
OEB
Post by rich on Oct 9, 2013 9:49:16 GMT 1
The only problem I can see it the side stand mount gets in the way of the lower frame rails. You could use some pieces of wood to level it up but then it gets a bit unstable. An easier way may be to use the centre stand and a single axle stand under the front frame cross tube?
Post by robin on Oct 9, 2013 9:50:04 GMT 1
For £80ish seems like a good deal, cant make up where the winding handle goes, or if there is anywhere to chock it in the up position, but for the odd fettling seems good to me, may even get one myself for that price..
Post by winnerevo1 on Oct 9, 2013 10:13:21 GMT 1
An easier way may be to use the centre stand and a single axle stand under the front frame cross tube? That's exactly how I do it.
Post by copper99 on Oct 9, 2013 20:53:55 GMT 1
An easier way may be to use the centre stand and a single axle stand under the front frame cross tube? That's exactly how I do it. Does that drop the rear low enough to remove the swingarm/suspension unit ?..
Post by winnerevo1 on Oct 9, 2013 21:00:19 GMT 1
Yes, I've not found the need to use a different type of stand.
Post by muttsnuts on Oct 10, 2013 11:38:35 GMT 1
richb
Post by richb on Oct 10, 2013 13:34:08 GMT 1
I use an ABBA stand with various attachemts that they do works a treat. Also use this workbench. Have built 2 of these one for myself and one for my other halfs brother Scott for when he goes racing. Comes apart an stows away nicely. Have applied 2 coats of varnish to them and on Scotts have trimmed the top with aluminium channel as his comes apart alot more and gets chucked in and out of the van/garage. Scott has had his SP1 on it with no issues and I have even put my CB1300 on mine. So much easier working on a bench than on the floor. Can make it whatever height, width, length you want, ideally need a ramp to get bike on and off as well. www.bbcracing.com/old/box/
Post by copper99 on Oct 10, 2013 19:56:22 GMT 1
Just bought that...cheers mate.
Post by muttsnuts on Oct 10, 2013 21:56:40 GMT 1
glad I could be of help.......
