Post by kevk on Oct 7, 2013 23:08:23 GMT 1
Hi guys Newbie here have just purchased a project F2 and want to ditch the fairing so the belly pan and fairing side pieces are up for grabs...red/white not in bad nick would prefer a swap deal if poss - oh a round headlight to go with it would be nice! Cheers
Post by LC_BOTT on Oct 8, 2013 8:38:45 GMT 1
Hi and welcome, if you're after an original, they don't go cheap, and I think, you'll also need the 31K frame to mount it to as well, unless you can cut and modify yours?? indicators fit on to this too, so not an easy job to swap, but nothing that needs to put you off either. Going for the belly pan as well? Stick some pics up of what you've got too.
Post by kostas on Oct 9, 2013 19:07:52 GMT 1
Aren't the belly pan mounts on the frame different than the ones on the full fairing bikes? there is quite a lot to do to get this mod look right..
good luck
kostas
Post by soccersmyth on Oct 9, 2013 20:24:49 GMT 1
Post by bare on Oct 11, 2013 4:15:03 GMT 1
I have an LC2 bikini fairing/windshield.. No frame for it though, but it does have those teardrop turn signal things stuck on it. Frankly the Plastic is a bit grotty, having been crashed, plastic weld repaired and ground to shape but not yet smoothed and painted. Windshield is dark coloured.. OEM? dunno, but it's intact. I have No use for it at all. Although I suspect shipping from the West Coast of Canada could be silly priced .. But?
Post by oldelsieboy on Oct 11, 2013 7:22:11 GMT 1
Hi guys Newbie here have just purchased a project F2 and want to ditch the fairing so the belly pan and fairing side pieces are up for grabs...red/white not in bad nick would prefer a swap deal if poss - oh a round headlight to go with it would be nice! Cheers Oh look, another wanted ad posted by a newbie with less than a 25 post count & again no mod intervention, what's the point in having a rule if its not policed correctly
