Post by Yogi on Sept 30, 2013 20:30:48 GMT 1
. Hi All Can anyone tell me the best size rear cog to go with a 17 tooth 8-)on the front of my lc2 hybrid I know there's a chart on here but can't find it Cheers Matt
Post by botty on Sept 30, 2013 20:37:19 GMT 1
I think you might find the chart your after in Norbo's swirly bit on the forum homepage. I think it's there.
Post by rich on Sept 30, 2013 20:44:51 GMT 1
Depends what you want really. 39 is standard but you would get a bit more acceleration by fitting a 41.
Post by Yogi on Sept 30, 2013 20:56:42 GMT 1
:PCheers botty It was there,rich I'm after a bit more acceleration, so I'm after a 43 to 45 as I could only get a 17 tooth offset from NK unless I waited,,no patience though
Post by midlifecrisisrd on Sept 30, 2013 21:05:07 GMT 1
Have you got a 17 or 18 inch rear tyre ? Was just thinking that. 17 rear with a 41 tops out at 110 - 115 if you over rev a bit. Thinking of downing to a 39 on mine as bounces off the limiter in top. Steve
Post by Yogi on Sept 30, 2013 21:18:25 GMT 1
Getting to old for a ton plus,,I've got a 17 in rgv rear,,shoul I go smaller?
Post by midlifecrisisrd on Oct 1, 2013 8:07:52 GMT 1
Getting to old for a ton plus,,I've got a 17 in rgv rear,,shoul I go smaller? 41 should be fine then, any bigger and you will be screaming it at 70 Steve
Post by Norbo on Oct 1, 2013 8:10:56 GMT 1
Post by alexx on Oct 1, 2013 10:34:12 GMT 1
maybe a bit off topic .. is there a 520 sprocket (F/R) for F2 available ?
Post by oldelsieboy on Oct 1, 2013 10:41:35 GMT 1
maybe a bit off topic .. is there a 520 sprocket (F/R) for F2 available ? Doesn't an F2 have a 520 chain & sprocket as standard? OEB
Post by rich on Oct 1, 2013 11:15:00 GMT 1
maybe a bit off topic .. is there a 520 sprocket (F/R) for F2 available ? Doesn't an F2 have a 520 chain & sprocket as standard? OEB Yep
Post by Yogi on Oct 1, 2013 15:03:30 GMT 1
520 IS STANDARD
Post by alexx on Oct 1, 2013 16:52:59 GMT 1
ok thanx
higgsy
Post by higgsy on Oct 2, 2013 20:12:56 GMT 1
Same sprocket is fitted to the TZR250 2MA/1KT if that helps
Post by Yogi on Oct 3, 2013 0:19:25 GMT 1
Cheers higgsy and everyone else
