dal68
Post by dal68 on Sept 22, 2013 17:47:18 GMT 1
can anyone tell me the charging rate on 350lc mine seems to be cooking the battery with a multi meter in place and at 5000rpm its reading 16.5 volts any ideas welcome
Post by cb250g5 on Sept 22, 2013 17:59:57 GMT 1
That's too high. Try a new / spare rectifier/regulator unit. I'm not well up on LCs, but on the valve it's a combined unit.
Post by muttsnuts on Sept 22, 2013 18:45:27 GMT 1
yup, way too high, sounds like the rectifier is shot
Maximum should be around 14.3 to 14.5v, anymore and you will cook the battery for sure
dal68
Post by dal68 on Sept 22, 2013 20:59:15 GMT 1
cheers chaps I take it there available from norbo or yambits is it one unit rectifier/regulator or two
Post by Shytalk on Sept 23, 2013 8:34:04 GMT 1
cheers chaps I take it there available from norbo or yambits is it one unit rectifier/regulator or two Just one unit does the job on the 350, max charging voltage should be @ 14.5V.
Post by 4l04ever on Sept 23, 2013 9:54:56 GMT 1
They don't fail very often, so loads of good used ones available too.
