Mot time
Sept 21, 2013 9:40:06 GMT 1
via mobile
Post by martyngsxr1 on Sept 21, 2013 9:40:06 GMT 1
Well it's going in for its mot fingers crossed it passes but if it doesn't ill have more to work on
Cheers martyn
Post by marsbar350 on Sept 21, 2013 9:49:26 GMT 1
good luck martin they will be too busy saying "dont see many of these about" to be too strict on the mot
Mot time
Sept 21, 2013 10:07:52 GMT 1
via mobile
Post by martyngsxr1 on Sept 21, 2013 10:07:52 GMT 1
I hope so but it does look scabby as one of the previous owner loved a paint brush and a tin of hammerite black
Post by Paul Dawkins on Sept 21, 2013 14:46:37 GMT 1
Bet I could pass it. Good tyres, no play in the bearings and its passed. lights can usually be sorted at the MOT and the headlight aim I adjust as I MOT the bikes. Brakes very rarely fail, 1mm in the minimum requirement for brake pads if there sintered.
Mot time
Sept 21, 2013 15:38:34 GMT 1
via mobile
Post by martyngsxr1 on Sept 21, 2013 15:38:34 GMT 1
Well it passed apart from a advisory about the doglegs now there shouldn't be any side to side movement when it's on the centre stand also it decided to playsilly buggers on the way home dropping to 1 cylinder then coming back on song a bit hairy but going to fit a new set of plugs in a minute
