Post by ngordoncrosby on Sept 21, 2013 5:55:34 GMT 1
Bottom bearing on the connecting rod has decided to give up ,which has kind of impacted onto the piston and broken the bottom end off.i suppose one way of looking at it ,it could of been worse..... Question is do I take the motor out ,or can I leave it in ??
Post by jessy03 on Sept 21, 2013 7:10:21 GMT 1
Engine out and rebuild me thinks, looks like its got very hot in there. Dont you just love two strokes - give you something to do over the winter though Jess
Post by fatfastroger on Sept 21, 2013 7:50:05 GMT 1
There will be bits of piston down inside and maybe got in to the main crank bearings too . Major failure there, so its a crank rebuild required too. Good luck - but you need to check the two stroke lube delivery as it looks like it aint had any recently.
Post by ngordoncrosby on Sept 21, 2013 10:57:51 GMT 1
Have already found plenty of piston...Plenty of oil in the delivery tube so I am thinking maybe the oil into the carb got blocked which caused it to get hot..The crazy thing was it was going really well,did not even expect it to go POP
Post by fatfastroger on Sept 21, 2013 12:19:12 GMT 1
They always go really well just before a big bang LOL
Post by arrow on Sept 21, 2013 14:36:04 GMT 1
Have already found plenty of piston...Plenty of oil in the delivery tube so I am thinking maybe the oil into the carb got blocked which caused it to get hot..The crazy thing was it was going really well,did not even expect it to go POP The pipes can be full of oil but the movement can be nil in overrun conditions if the stroke is zero.
Post by ngordoncrosby on Sept 23, 2013 5:37:17 GMT 1
just put a gauge on the barrel,is 54 the standard size..?? RD250lc
Post by arrow on Sept 23, 2013 16:10:02 GMT 1
Yes 54mm standard bore.
Post by ngordoncrosby on Nov 3, 2013 4:55:45 GMT 1
Thanks Norbo,for the flywheel puller .worked well ,so good when you have the right tool
Post by ngordoncrosby on Nov 3, 2013 11:00:35 GMT 1
Pulled the motor apart..Got my self a Haynes manual and read it.Enjoyed my dump so what would you like me to do next?..?
Post by Roofmonster on Nov 3, 2013 12:00:32 GMT 1
Pulled the motor apart..Got my self a Haynes manual and read it.Enjoyed my dump so what would you like me to do next?..? Find a good crank builder,rebore,pistons,gasket set,oil,blood,sweat and tears etc oil,blood,sweat,tears and cash
Post by ngordoncrosby on Nov 3, 2013 19:11:42 GMT 1
Rebore is already happening.Just had to go up to the first size .25 pistons.Not looking forward to the crank rebuild
Post by arrow on Nov 3, 2013 19:50:56 GMT 1
Make sure that oil pump is working ok. You can do it yourself, if you want, just make sure you are 100% happy with it.
Post by wallcraft on Nov 3, 2013 20:34:54 GMT 1
Yes the oil pump should be the very next thing to be rebuilt accurately, Arrows the man,he has done 2 for me, first one was uprated standard one 2nd was his production modified one. Very happy with both. Mark.
Post by carioca656 on Nov 3, 2013 22:10:54 GMT 1
how much is a pump rebuild?
Post by stanlc7189 on Nov 3, 2013 22:49:58 GMT 1
I think Arrow charges about £45, but check by PM ing him. The stroke is critical. My oil pump was fine, but had zero stroke - end result? Blown crank! I refurbed my pump, with advice from Arrow, and set the stroke to 0.3mm. Smokes like a b*****d now, but that confirms it's getting lots of oil through. There are lots of road situations when you shut down at high rpm and unless you have the right stroke your engine will be starved of oil temporarily. The refurb is easy, but for £45 I'm going to send my spare pump off to Arrow. He's the oil pump man!
Post by Roofmonster on Nov 3, 2013 22:56:43 GMT 1
+1 Arrow does a brilliant service - pump comes back like new!
Post by arrow on Nov 3, 2013 23:18:21 GMT 1
Cheers Guy's. Yes, the re-build service is £45.
Post by ngordoncrosby on Nov 4, 2013 3:55:01 GMT 1
Post by ngordoncrosby on Nov 13, 2013 7:38:33 GMT 1
Is there a factory spec for a first rebore on .25 pistons or do you just leave it up to the engine recond guys??
Post by hampo on Nov 14, 2013 22:24:11 GMT 1
Buy the pistons first & give them to your rebore man with the barrels. He'll do the rest if he knows his onions.
Post by oldelsieboy on Nov 14, 2013 22:47:00 GMT 1
Send your crank & barrels to PJME they will rebuild the crank, reborn the barrels & supply the pistons, rings etc. OEB
Post by chippy348 on Nov 14, 2013 23:52:51 GMT 1
Be careful buying pistons first as if they don't clean up at 0.25 you may have to go out to + 0.50 Best to ask the place who is doing the work.
Post by Denzil on Nov 17, 2013 10:58:44 GMT 1
Arrow is the man for your pump. He knows what he is doing and it's one less thing to worry about in my opinion.
