Post by thehut on Sept 14, 2013 14:08:14 GMT 1
does any one know what way the wiring from the cdi goes behind oil tank on lc350. it seems to get jammed behind tank. not sure if it should go inside shocker cover then out under seat.
Post by ulsta on Sept 14, 2013 14:43:34 GMT 1
Think it runs up the mudguard on the battery box side. Not at home atm so can't check.
Post by thehut on Sept 14, 2013 15:49:24 GMT 1
ok cheers. mine been put up wrong side if it does
Post by ulsta on Sept 14, 2013 16:21:38 GMT 1
I think there's a couple of clips on the bottom corner of the mudguard that the wiring pushes into to hold it.
Post by thehut on Sept 14, 2013 17:31:46 GMT 1
ok ill have look cheers
