Post by carioca656 on Sept 12, 2013 22:04:06 GMT 1
hi if I rebore my 350lc cylinders to 2.5 oversize will I need bigger head gasket if so where would I get one
big bore
Sept 12, 2013 22:29:37 GMT 1
via mobile
Post by Deleted on Sept 12, 2013 22:29:37 GMT 1
I wouldn't rebore to plus 2.5mm as would leave the liner too thin. Best to get it resleeved
Post by Norbo on Sept 12, 2013 23:12:09 GMT 1
Yes but that's not cheep mate and can take ages to do . you may fined that the piston hits the inner ring. id get the barrels done to take a TZ O ring my self /
Post by lb on Sept 13, 2013 4:01:05 GMT 1
Either way,Wicked does a copper o/s head gasket.(Sorry Norbo)
Post by Norbo on Sept 13, 2013 7:03:33 GMT 1
Then the simple way would be the copper one but a normal head gasket will be to small and the piston will hit the inner ring so this seems like the way to go .
hrc43
Post by hrc43 on Sept 13, 2013 8:21:05 GMT 1
where can i get hold of one of those copper head gaskets
Post by Norbo on Sept 13, 2013 8:54:01 GMT 1
You only need them on 2mm and over pistons remember
Post by 4l04ever on Sept 13, 2013 19:04:08 GMT 1
Use a standard original Yamaha head gasket which has a bore size of about 65mm and open it out using a dremmel...
I have seen barrels bored to 3mm oversize using other pistons on a 4L0, so is do-able....
I had problems with copper head gaskets so went back to original Yamaha ones bored out.
Post by bare on Sept 14, 2013 3:33:14 GMT 1
As above, Copper head gaskets .. Suck Not to put too fine a point on it :-)
Post by seahorse83 on Sept 15, 2013 0:19:09 GMT 1
I thought it was a reasonable idea LB, even if Bare didn't, just being his usual self which is crucial so we all get both sides of the fence. Please no offence intended Bare and I know you couldn't give a rats anyway, again I like that.
For me if I could I would go the O ring. my second choice, as I cant go an O ring would be my first choice the copper gasket. Considering the compressable ring set up on the OEM gasket it would be tricky to open it out. The copper can be re-annealed and re used. I would use a thin smear of holamar or another heat proof gasket material and us the copper. Just my two bobs worth.
Post by ianr4863 on Sept 15, 2013 21:08:41 GMT 1
Theres a guy on ebay uk from the USA . Copper gaskets unlimited I think . He will make one for you with any size bore you want . It will need a coat of Wellseal or similar on it if you use one . Search RD350LC head gasket and he comes up .
hrc43
Post by hrc43 on Sept 16, 2013 7:39:33 GMT 1
anyone know who does the o ring conversion
Post by Norbo on Sept 16, 2013 13:40:03 GMT 1
Faron engineering can do it 01159 634 123
Post by hardhatharry on Sept 16, 2013 15:25:53 GMT 1
Im on a +2 over bore on a 31K using standard gaskets should I be worried?
I did get the gaskets from the same place who did the bore and supplied the pistons and got a note on how to grind the powervalves back so they dont catch the piston in the package
