Post by Shytalk on Mar 28, 2006 11:16:28 GMT 1
I stripped down the front forks yesterday, found each leg had a different type / colour fluid in. What is the recommended fork fluid to use? the manual says to use engine oil. I was thinking of 20W fork oil personally and maybe junk the original springs and fit some Hagon progressive ones at the same time. Anyone got any thoughts or experiences with this? Almost forgot to add they are from a 31K LC2 with the air adjusters on them.
Post by mellow on Mar 28, 2006 15:53:45 GMT 1
my m8 has a 350 lc..........he's doin it up same time as i do my F2 he did his forks a while ago and he used engine oil of the viscosity rating the manual said
Post by Norbo on Mar 29, 2006 20:35:01 GMT 1
Id put an extra 10mmin each leg as well .
Post by Shytalk on Mar 29, 2006 21:15:59 GMT 1
Norbs, do you mean an extra 10ml of fluid or 10mm extra spacers?
Post by Norbo on Mar 29, 2006 21:43:53 GMT 1
10ml of fluid sorry . I cut a clutch spring in half and put that on top of the sping aswll.
