Post by 65 on Sept 1, 2013 17:08:15 GMT 1
Hello where can I buy a (two) complete repations set for carburetor with needles, nozzles, o rings, + div parts. it is a rd 350 year 86 think they called 1AU with jets. rep set must be of Japan's quality.
sincerely 65
denmark
Post by arrow on Sept 1, 2013 17:15:31 GMT 1
Post by 65 on Sept 1, 2013 20:05:41 GMT 1
fine website, but it was a kit I was looking for. is there anywhere else?
65 denmark
loop
Post by loop on Sept 1, 2013 21:10:16 GMT 1
65, look at: yambits.co.uk/rd350-ypvs-late-carb-repair-kit-p-2145.html I do not consider original quality, o ring smaller, etc. But it can get you going whilst ordering individual orig parts as needed, from Allens or Mr Norbo. PS check your engine number, this is for late f2's, they have diff kit for earlier models.
Post by 65 on Sept 1, 2013 22:13:19 GMT 1
thanks ... found something on ebay: Yamaha Keyster RD 350 YPVS 1WW Kit Dichtungssatz Reparatursatz Vergaser? do not know if it fits my 1WT. is probably best Keyster (made in japan) .. thanks for the help
65
Post by winnerevo1 on Sept 1, 2013 23:03:28 GMT 1
Keyster carb kits have a poor reputation.....
Post by arrow on Sept 1, 2013 23:32:47 GMT 1
Keyster carb kits have a poor reputation..... +1
Post by 65 on Sept 2, 2013 20:05:14 GMT 1
ok ... the original parts are too expensive .. so I need to find something out on the web. I will look on ebay, I think I saw something in holland
65
Post by grancio28 on Sept 2, 2013 21:06:13 GMT 1
Nothing wrong with keyster kits in my opinion! Just make sure you get the correct kit! Many people say the float valves don't seal, I had the same problem but setting the fuel level instead of float height sorts that out!
Post by 65 on Sept 3, 2013 19:30:39 GMT 1
Are there any companies other than Keyster? also believe that it is a good quality Keyster
65
Post by bare on Sept 4, 2013 0:50:24 GMT 1
Nothing wrong with keyster kits in my opinion! J PT Barnum would be Proud! Rest of the world thinks Keyster is utter garbage. Clearly they/we are all wrong.
Post by Shytalk on Sept 4, 2013 10:01:56 GMT 1
Nothing wrong with keyster kits in my opinion! Just make sure you get the correct kit! Many people say the float valves don't seal, I had the same problem but setting the fuel level instead of float height sorts that out! On the other hand; I have until now; not seen anyone say anything good about keyster kits and wouldn't trust them.
Post by 65 on Sept 4, 2013 11:51:23 GMT 1
It's not easy! What is your opinion about this kit? kopirer it into the google
Yamaha RD 350 LC_YPVS_Typ:_1UA_Vergaser_-_Reparatur - Sets_carburator rep-set
65
Post by 47x on Sept 4, 2013 12:44:24 GMT 1
DONT buy keyster kits,total crap mate..
Post by thehut on Sept 4, 2013 19:02:17 GMT 1
iv baught them a few times and never had prob with them
Post by 47x on Sept 4, 2013 19:13:47 GMT 1
very LUCKY.....
higgsy
Post by higgsy on Sept 6, 2013 8:46:46 GMT 1
Out of desperation the other week I used the float valves from the keyster ones that I've had kicking around for years, no problems so far and they solved the overflowing carb issues that have plagues my YPVS race bike since day one.
I guess I was just lucky in this instance, but who knows. I wouldn't normally use them having had a nightmare with the TZR replacement bits.
Post by davey on Sept 6, 2013 21:08:30 GMT 1
Used keyster in all 3 of my bikes, no probs at all. Nrp carbs in manchester is where i got mine from. Call andy , very helpfull guy
Post by 65 on Sept 7, 2013 19:33:14 GMT 1
yes it seems that he has the right kit (Keyster) ... but it is unbelievable that you can not find a Mikuni kit!
ron
