Post by Yogi on Aug 31, 2013 21:52:35 GMT 1
Start of my hybrid picture is in my avatar as I can't work out or find how to use photo bucket,,,any help please? I tapped the needle bearings into the swing arm 7mm each and cut the excess off with a grinder and cleaned around the welds with a file until the cups fitted back on. The rd spindle is 3mm smaller than the suzi one,,,Question? Should I have bushes made or get frame drilled to take gsxr spindle? Thanks for any help
m1ke
Post by m1ke on Aug 31, 2013 22:08:23 GMT 1
Bushes made so if you ever want to go back you can....
Post by winnerevo1 on Aug 31, 2013 23:05:51 GMT 1
can't work out or find how to use photo bucket,,,any help please? What is it that you're not sure about, have you uploaded your pics to photobucket? Say where you're at and what you're stuck on and I'll talk you through it...
Post by Yogi on Aug 31, 2013 23:08:29 GMT 1
can't work out or find how to use photo bucket,,,any help please? What is it that you're not sure about, have you uploaded your pics to photobucket? Say where you're at and what you're stuck on and I'll talk you through it... [/quote Can't work out how to find photo bucket? Cheers winnerevo
Post by winnerevo1 on Aug 31, 2013 23:15:35 GMT 1
Click for Photobucket..You must open an account (free) then you can upload your pictures to your photobucket account.
Post by Yogi on Sept 1, 2013 0:05:55 GMT 1
Still can't upload album,,,is it cos I'm on an iPad?
Post by winnerevo1 on Sept 1, 2013 0:45:08 GMT 1
You make a new album on Photobucket and use bulk upload to upload multiple images.
Post by Yogi on Sept 8, 2013 11:05:00 GMT 1
Hi gang
On the rear conversion I ground the end off the gsxr needle bearings and slotted back in the swing arm The rd needle rollers fit perfectly inside, I've got to get 7mm shaved off the sprocket carrier now ,,,
Question? Can I use the rd chain which is a 520 on the gsxr sprocket which is 525'or do I use the gsxr chain?
Thanks for any help,,,Matt ;)l
m1ke
Post by m1ke on Sept 8, 2013 11:36:23 GMT 1
If you can find a 525 sprocket that will fit one the gearbox end you could...
Post by Yogi on Sept 8, 2013 12:36:46 GMT 1
Cheers Mike I've found a gold 520 chain on the bay that'll fit the gsxr sprocket and give me abit more room through the frame
matt7
Post by matt7 on Sept 8, 2013 15:38:32 GMT 1
GS500e sprocket carrier should do the job, I got one for mine - cheaper than machining - unless you got a decent size lathe ! Early model GS fits, don't know if later model the same ?... Get some pic's up edit - get a 520 sprocket
Post by Yogi on Sept 8, 2013 16:05:34 GMT 1
No matter how much I try just can't do pics on my iPad ?
Cheers for that Matt 7 i will try that .
Have you fitted one before?
