Post by baz69 on Aug 31, 2013 17:07:58 GMT 1
hi all,just in process of putting bike back together,took fuel tap off tank to clean ,question is when putting back do i need to put a smear of sealant on fuel tap rubber seal, or just replace seal or both replace and sealant,seal isnt perished just dont want a leak from tank
Post by Shytalk on Aug 31, 2013 17:24:10 GMT 1
I've never had a problem with just using the rubber seal, but if you want to use anything on it use rubber grease so as not to perish the seal.
Post by Roofmonster on Aug 31, 2013 17:28:11 GMT 1
+1 - I just put a smear of rubber grease on the O ring
