Post by Deleted on Aug 27, 2013 15:18:36 GMT 1
Ordered some kenny pipes but when I looked at some kennys pipes I don't think my carbon belly pan will go on Won't butcher it to make it fit as its very rare
Post by Bozzy on Aug 27, 2013 15:29:11 GMT 1
thats supprising as I found Kenny pipes actually ran as close as standard on my PV. I had to make extended brackets with the Nikkon set but when putting on Kennys I found found the pipes ran more tucked in. However the pipes do run close to the pan had to get some heat shield fabric off ebay and it has worked a treat no probelms.
I Assume depends where its hitting if at the front the not much can be done....
Post by Deleted on Aug 27, 2013 15:38:51 GMT 1
mutts nuts should get his kennys pipes this week so will have a run up to his with my belly pan to see if it fits, might just be me worrying for nothing
Post by midlifecrisisrd on Aug 27, 2013 16:34:56 GMT 1
You might be ok, just had a look at mine and the don't flare till after where the belly pan is.
Might just need dropped a bit with brackets.
Post by muttsnuts on Aug 27, 2013 16:46:07 GMT 1
if they arrive I'll let you know Mick, I also have some brilliant (read expensive !!) heat sheild material which I use on the MV to keep the fairing from melting etc
Post by wallcraft on Aug 27, 2013 18:19:06 GMT 1
Will the centre stand fit nice?
Post by steve h on Aug 27, 2013 22:15:15 GMT 1
Don't faff around mick, if the belly pan fouls on the pipes, get a ballpein hammer and dent the pipes in the offending area!!! Or you could hacksaw a chunk out of the belly pan, I've got a spare hacksaw blade with a few teeth left in it(got it off ebay for £6 + £6pp,) which I could hire out to you, for a small fee ( + p&p) HTH.
Post by scott on Aug 27, 2013 22:29:34 GMT 1
just give me the belly pan,simples
Post by winnerevo1 on Aug 27, 2013 22:33:19 GMT 1
Just space the bellypan away from the pipes if it's too close. Would easily get a bellypan on my 421 with Kenny's pipes.
Post by 4l04ever on Aug 27, 2013 23:21:34 GMT 1
You could get kenny to make a set that stay tucked in more.....
