Post by bazilfox on Aug 26, 2013 21:36:12 GMT 1
Hi Folks. I have put an RD 31 k engine into a Suzuki Rg 250 Gamma frame to make a Hybrid YammaGamma following some information I got from a old 80s issue of Performance Bikes written by Stan Stevens ( Limited Information). So far the job has gone OK but could any one please help me with the problem of fitting the RD throttle cable & adjuster along with the Gamma Twist grip hsousing because the two do not go together at all. I have tried to find a full throttle twist grip/switch housing for the RD on the internet but no results. Perhaps these are quite hard to come by ? Any advise would be much appreciated & I reckon there must be someone out there who knows about this stuff. Cheers Baz.
Post by gammaguy21 on Aug 28, 2013 14:40:06 GMT 1
On my mk3 yammagamma, if remember right, having to open/modify the hole for the ypvs throttle cable end. It would still hang every once in a while, so I ended up just using a rz throttle tube. No fitting issues whatsoever and worked like it should. I was able to pick one up new from the local Canadian Yamaha dealer.
I'm sure used ones turn up on ebay once in a while.
Post by bazilfox on Aug 29, 2013 14:18:47 GMT 1
Thanks for the advice Gammaguy. I have attached the throttle cable to the gamma housing but as you said it just kind of hangs out and is not fixed in properly. I have checked on ebay and think I have found an RD throttle housing / switchgear which hopefully will solve the problem. Cheers Baz.
