Post by 47x on Aug 26, 2013 19:39:31 GMT 1
well chaps,wat you think,should I go for it??
Post by flames on Aug 26, 2013 20:30:58 GMT 1
course you should.
Post by Deleted on Aug 26, 2013 20:32:58 GMT 1
Depends how big you are as mito's are small. I am only five foot eight and sat on one yesterday and did feel very small
Post by 47x on Aug 26, 2013 20:46:07 GMT 1
yeh,used to work as a cagiva/aprilia mechanic so know there small m8.but if I get it for the right price I might go for it as they are nice,sweet handeling bikes,but SO unreliable!!
Post by Deleted on Aug 26, 2013 21:08:16 GMT 1
And it's going to be more reliable with a power valve engine?
Post by 350wayne on Aug 26, 2013 22:00:35 GMT 1
YES DO IT MATE !!! I'm just starting the same project , bought a mito frame ( with the ypvs conversion kit ) from Dex 46 ( thanks Andy ) and I'm going to use the power valve motor from my lc hybrid project which I've now put on hold to progress the mito 350 ..... Have you got a ypvs motor already or are you starring from scratch ?
Post by 47x on Aug 26, 2013 22:01:25 GMT 1
hahaha.of course..after I rebuilt it...hahahah
Post by blyth1970 on Aug 26, 2013 22:15:44 GMT 1
go for it, and post lots of pics
Post by 47x on Aug 26, 2013 22:19:27 GMT 1
I will if I go for it,hey andy(dex 46)hope the f2 pipes were ok chap//WAYNE..doing it from scratch m8y,but have not got it yet,will see wat happens,but will need all the ypvs stuff.howz the bike coming on dex??
Post by 2strokesmoke on Aug 26, 2013 22:22:28 GMT 1
Do it do it do it ..with lots of pics and progress reports
Post by 47x on Aug 26, 2013 22:28:04 GMT 1
of course 2strokesmoke!! naturally....
Post by 47x on Aug 26, 2013 22:32:47 GMT 1
hey wayne,is that the one you bought for £225???hope you don't mind me asking??
Post by 350wayne on Aug 26, 2013 22:37:48 GMT 1
Yes , that's the one mate , I've been wanting to do the mito 350 thing for a while now and now I've got ( most ) of the parts I need ))
dougb
Post by dougb on Aug 26, 2013 22:38:47 GMT 1
Go for it, mine rocks, and their loads more reliable with a valve motor in....
Post by 47x on Aug 26, 2013 22:41:38 GMT 1
hey doug,hope to get info of you if that's ok chap??and I believe you about valve motor mate.
Post by 350wayne on Aug 26, 2013 22:49:20 GMT 1
Hey Doug , what does your mito 350 handle like , and what is the spec ? Any tips would be VERY helpfull )
dougb
Post by dougb on Aug 26, 2013 23:00:52 GMT 1
Hey Doug , what does your mito 350 handle like , and what is the spec ? Any tips would be VERY helpfull ) it handles pretty well to be honest,could do with someone who knows about suspention to do some final setting up on the front end,but m happy with it. basic specs are : martin77 mid range tune and pipes to match pwk 28's with tdr reeds on pod filters tss upgraded bearings aprillia rs 250 front end and rear wheel mito sp shock r1 clocks magura hydralic clutch ask any question's you want and i'll do my best to answer,if your near wiltshire come and have a look
Post by turbopresh on Aug 26, 2013 23:12:36 GMT 1
YES DO IT MATE !!! I'm just starting the same project , bought a mito frame ( with the ypvs conversion kit ) from Dex 46 ( thanks Andy ) and I'm going to use the power valve motor from my lc hybrid project which I've now put on hold to progress the mito 350 ..... Have you got a ypvs motor already or are you starring from scratch ? So thats where that went! I was seriously considering going for a second one im enjoying building this one so much lol.. damn you doug, you've done too much tasty stuff to yours lol your going to break my bank if i keep seeing the photos/specs of your machine.. would love a wee set of pwk28s.. you should definately go for it mate.. great fun seeing a brilliant idea come to fruition!!
Post by 350wayne on Aug 27, 2013 10:25:18 GMT 1
Hey Doug , that's a very tidy mito 350 mate ! I'll be asking questions for sure when I get started on my project ( October ) ... I'd love to come and look at it but i 'm in Nott'm so not exactly round the comer ( First question is , what rad are you using ? Best regards Wayne
Post by 47x on Aug 27, 2013 10:55:19 GMT 1
the mito one is fine for even a tuned valve motor wayne,the top hose even goes straight on(sort of!),but the bottom one needs a custom one.hth.
Post by turbopresh on Aug 27, 2013 11:49:18 GMT 1
I'm running my rad backwards.. had the bottom inlet rotated 90degrees and a filler cap added as recommended by Doug.. picking it up today.. excited.com
Have heard reports of the rad coming into contact with the front wheel.. but I've bounced the shit out of it and it seems to be a fair bit off it..
Post by 350wayne on Aug 27, 2013 13:28:07 GMT 1
Right thanks for that , mito rad it is then ; luckily mito spares are cheap too . I've got a 916 front end ready to go in and a trick carbon seat unit for it as well ..... Can't wait to get stuck in to it !!!!!
dougb
Post by dougb on Aug 27, 2013 14:27:03 GMT 1
When I ran my rad backwards it would hit the tyre under hard braking, I moved the rad forwards a bit and turned it the right way round.....there should be a pick of the rad brackets on my bikepics page.... Mmmmmmm.....carbon :-)
Post by 47x on Aug 27, 2013 17:22:05 GMT 1
not going to bother chaps,just want something already done/needing little work,just don't have the funds...oh well,nice thought while it lasted..good luck wayne350 and turbopresh/doug.
Post by turbopresh on Aug 27, 2013 21:10:17 GMT 1
im going to get my heavy friend round to compress the forks.. yeah i saw the wee brackets you made up.. if i run it the right way round i'll have to reweld the lower pipe back in the original position.. could maybe try moving it up a tad if it becomes an issue.. all a work in progress at the moment lol which reminds me i need to busy myself with making a flywheel holder so i can get the flywheel nut torqued up and forget about the motor!
Post by 47x on Aug 27, 2013 22:08:45 GMT 1
good luck turbopresh,will still see how the build/thread goes mate,very interested!!
