Post by dave1967 on Aug 26, 2013 13:48:00 GMT 1
Got2 brand new.horns off Norbo and tried them a few days ago went back to them today and neither work..they click...is there another fuse anywhere besides the 4 in the box..sure battery id ok as power valves and lights work..should they work if i put directly to battery..both cant be duds.
Post by arrow on Aug 26, 2013 13:50:05 GMT 1
Any difference with the engine running?
Post by 47x on Aug 26, 2013 13:52:39 GMT 1
probally the screws need adjusting chap
Post by dave1967 on Aug 26, 2013 14:03:15 GMT 1
ive adjusted the screws..even though they both worked perfectly the other day..i cant run the engine yet as its not ready..should horns work directly off a battery?
Post by 47x on Aug 26, 2013 14:05:55 GMT 1
yep,sure you haven't blown them though???if its a 12 volt battery,cant see why they should have blown tho?
Post by arrow on Aug 26, 2013 14:06:15 GMT 1
They should work directly off the battery yes. Try them on your car battery as a second check.
Post by dave1967 on Aug 26, 2013 14:10:08 GMT 1
tried both off car battery and neither work..how could i have blown them?
Post by arrow on Aug 26, 2013 14:12:53 GMT 1
Are they fussy about polarity? Just a thought.
Post by andygasgas on Aug 26, 2013 14:21:28 GMT 1
I've got exactly the same problem tried 3 new horns so far all worked once or twice then click nothing on the bike they blow the fuses tried engine running nothing car battery nothing and 1 more new 1 reversed polarity same again
Post by dave1967 on Aug 26, 2013 14:27:42 GMT 1
yes these worked for a couple of beeps and now just a click or a buzz..what can cause that..ive not blown any fuses and its all wired up correctly?
Post by 47x on Aug 26, 2013 14:30:11 GMT 1
must be poor quality horns if it happened to a few people(if from same supplier)although norbs stuff is usually top notch??
Post by raven13 on Aug 26, 2013 14:34:46 GMT 1
had the same problem with my single horn. i gave it a couple of taps while pressing the horn button and it made it work. not had any problems since
Post by dave1967 on Aug 26, 2013 14:47:10 GMT 1
mine are the 100mm black rivet ones
Post by dave1967 on Aug 26, 2013 14:54:07 GMT 1
ive tried that..nothing happens..but worked perfectly the other day.
Post by thehut on Aug 26, 2013 15:04:17 GMT 1
put a meter across the terminals on horns to see if coil has gone on them. if you have one
Post by turbopresh on Aug 26, 2013 15:52:35 GMT 1
What thehut says.. check for continuity across the horn..
Post by thehut on Aug 26, 2013 16:04:25 GMT 1
would you believe it i baught a second hand pair off ebay bout 3 weeks ago. just tryed them on and they both shot. coils are gone in them. so sent him msg see what happens. as he selling another pair. on ebay
Post by Norbo on Aug 27, 2013 7:44:41 GMT 1
Try the adjuster screw on the back nearly every time that will do it . Stuff like horns are made in the 1000's so you do get duff ones some times but ive only ever had 1 set returned as 1 didn't work I adjusted the srew on the back and then it worked fine.
Post by brownsauce on Aug 27, 2013 11:56:27 GMT 1
I'm having the same problem, l didn't know you could adjust them I'll try it later let you know how I get on .
Post by dave1967 on Aug 27, 2013 22:32:37 GMT 1
Sorted..git my daughter to hold button in and turned screw and middle bolt and they work..one more headace sorted.
Post by brownsauce on Aug 28, 2013 10:36:03 GMT 1
Tryed adjusting the screw on mine, got it working better then it blew a fuse! Any ideas anyone?
Post by andygasgas on Sept 6, 2013 17:13:38 GMT 1
We found that the centre bolt that mounts the horn to the bracket was earthing it out so wrapped bracket in tape and yep works fine now
