Post by looey on Aug 26, 2013 10:33:42 GMT 1
Anyone here an expert on setting up the YPVS on the TZR125 ?.
I've got a 1989 2RK (UK restricted) TZR125 that has has a full YPVS system fitted.
I've done some research and apparently the only restriction on these bikes was the Valve pegged in the closed position and no Servo etc. fitted.
This bike has nice low down power but it just doesn't have the power it should have up in the revs.
I've checked the valve and cable settings and they look spot-on, i.e. does the cleaning cycle and sits in the fully open position with the ignition on and the bike not running, and when you start the bike the valve moves to the closed position and when you rev it it moves towards the open position.
Problem is..... the valve doesn't get to the fully open position until the revs get to about 10,000rpm, which is obviously far too late.
If I remove the cables and peg the valve in the fully open position I get exactly what you'd expect, no bottom end power whatsoever, then good power between 6,000 - 8,000rpm, then it goes ballistic from 8,000 - 10.500rpm.
I've looked at the pulley housing and that has 29L on it which I thought was a 350 YPVS part, or were they the same part numbers used on the TZR125 ?.
The problem I see is the fixed movement of the servo, so if I adjust the valve so it is fully open at lower revs then when the revs get higher the valve will continue past the fully open position and start to block the outlet track ?.
Anyone got any ideas on how to get it setup so the valve is fully open at lower revs ?.
And does anyone know what revs the valve should be open on the TZR125 ?. I have a Haynes manual but it doesn't cover the valve assembly cos it shouldn't have one fitted !!!.
Cheers
Cheers
