Post by dave1967 on Aug 25, 2013 22:15:04 GMT 1
Have got an exhaust stud that wont tighten..does this mean threads gone in casing..if so how do i solve it?
Cheers
Dave
Post by Deleted on Aug 25, 2013 22:27:43 GMT 1
Check the thread on the stud itself, if the look ok, it sounds like it could be the casing thread. Any decent machine shop could put a helicoil in there to fix it.
Post by dave1967 on Aug 25, 2013 22:37:13 GMT 1
Stud looks ok but ive got a spare one too so will try that first.
Post by turbopresh on Aug 25, 2013 22:52:10 GMT 1
sounds like its maybe pulled the threads out with it when you were pulling it out.. just heli-coil it.. can buy the kits on ebay for about 15 quid, gets you the appropriate sized drill-bit, tap and heli coil insert.. fantastic job, I've used them on quite a few occassions.. even made use of them when putting threads into my hybrid coil bracket..
Post by dave1967 on Aug 25, 2013 23:43:37 GMT 1
Im not sure if it.happened when i tightened it up a bit much
Post by arrow on Aug 26, 2013 0:12:35 GMT 1
The best repair if the threads are damaged in the barrel is a timesert insert. www.timesert.com/
Post by dave1967 on Aug 26, 2013 0:28:19 GMT 1
What size repair would i need..also what are toque settings if any are the exhaust bolts?
Post by arrow on Aug 26, 2013 0:32:58 GMT 1
I sent my barrels away to be done. here; www.westgatehill.com/arm.htm .Just keep checking the nuts are tight, without making them any tighter than standard, if that makes sense. It takes a while for the exhaust gaskets to 'bed' in.
Post by dave1967 on Aug 26, 2013 0:38:48 GMT 1
If i were to helicoil it what size would i need?
Post by arrow on Aug 26, 2013 0:47:27 GMT 1
A repair for an 8mm stud, unless I'm corrected.
Post by dave1967 on Aug 26, 2013 1:02:06 GMT 1
Are they easy to use or is it a job for a machinest?
Ruddy
Post by Ruddy on Aug 26, 2013 1:09:23 GMT 1
Easy to do, check out some u tube vids.
Post by dave1967 on Aug 26, 2013 1:14:31 GMT 1
Ok will do..so do i order 8mm..what length?
Post by turbopresh on Aug 26, 2013 1:26:52 GMT 1
Yeah 8mm x 1.25 I believe.. studs can be bought cheap as chips I don't really use a torque wrench for exhaust studs but probably about 15nm if I were to take a guess at what I put them at with the hand torque meter lol
Post by dave1967 on Aug 26, 2013 1:53:06 GMT 1
I think maybe i over tightened it then..but will try a new stud first just incase.
Post by turbopresh on Aug 26, 2013 2:15:32 GMT 1
Aye they don't need mental amounts of torque.. just make sure you tighten both sidesturn about to make sure the collar is being tightened evenly..
Post by LC_BOTT on Aug 26, 2013 6:59:23 GMT 1
You could try a longer stud or bolt as well first, it might have a few good threads at the bottom of the hole, but I would bet, sooner or later it will need doing properly as mentioned.
Post by stanlc7189 on Aug 26, 2013 12:28:41 GMT 1
I believe the torque setting for exhaust nute is 16 lbf ft, or 21 Nm if you work in metric
Post by turbopresh on Aug 26, 2013 13:34:33 GMT 1
Wasn't too far off then lol nice one
Post by dave1967 on Aug 26, 2013 13:43:52 GMT 1
I have solved it..the thread had stripped on the stud on the nut side but all sorted now...cheers for your help.
Post by arrow on Aug 26, 2013 13:48:07 GMT 1
I have solved it..the thread had stripped on the stud on the nut side but all sorted now...cheers for your help. That's a good result.
Post by dave1967 on Aug 26, 2013 15:37:29 GMT 1
Yes though it would be a good day until i tried horns..lol
Post by turbopresh on Aug 26, 2013 15:49:35 GMT 1
A fine stroke of luck mate.. you can stop sweating now lol
