Post by Yogi on Aug 25, 2013 18:24:34 GMT 1
Hi gang I've just won a gsxr400 on the bay! Does anyone the best place near Romford Essex to get the gsxr front and rear grafted onto my 31k,also a rough cost , Cheers Matt
Post by jessy03 on Aug 25, 2013 19:05:35 GMT 1
5mm spacer for the front end off norbo, the rear Gibson Exhausts might be able help. Jess
Post by jessy03 on Aug 25, 2013 19:05:47 GMT 1
Post by Yogi on Aug 25, 2013 20:52:13 GMT 1
Cheers Jess
dex46
Post by dex46 on Aug 25, 2013 22:18:15 GMT 1
As above mate 5mm spacer under bottom headrace bearing then front sorted for the rear give Nigel a call at NK Racing he make's a fitting kit to fit a rgv arm to fit straight in a 31k this also may be ok with the rear end you have but im not sure give him a call he will sort you out mate
Post by Yogi on Aug 26, 2013 9:17:11 GMT 1
Cheers Dex
Post by Yogi on Aug 26, 2013 20:08:15 GMT 1
Silly question,,do you just use the ypvs bearings?
dex46
Post by dex46 on Aug 26, 2013 20:56:24 GMT 1
If you are talking about the headstock bearing's yes use the powervalve bearing's mate
Post by Yogi on Aug 26, 2013 21:50:42 GMT 1
Nice one Dex I was on about them
