Post by seahorse83 on Aug 24, 2013 15:11:59 GMT 1
Evening ladies and Gents.
Just a quick one, before I purchase a second hand 30 year old CDI, was wondering will the Banchee CDI work.
Advanced thankyou's for technical reply from those that have succeeded or failed
Kind regards Seahorse
Post by flames on Aug 24, 2013 21:58:05 GMT 1
yep.several peeps on here have fitted them.rdlclazy has one fitted on his for one.there is a piece on fitting in advice or general.
Post by winnerevo1 on Aug 24, 2013 22:56:12 GMT 1
yep.several peeps on here have fitted them.rdlclazy has one fitted on his for one.there is a piece on fitting in advice or general. I think you are confusing this with the Banshee coils, the OP is asking about the CDI.
Post by seahorse83 on Aug 25, 2013 5:57:03 GMT 1
Does a banshee CDI work on an Lc 4L0 ?
Post by winnerevo1 on Aug 25, 2013 9:15:59 GMT 1
I don't know if it works with the 4L0 stator. Normally you need a matched cdi & stator. A banshee curve would be different to a 4L0, maybe trawl the Zeeltronic threads,especially for big bore motors as there's usually some curves posted in those threads.
Post by flames on Aug 25, 2013 11:05:23 GMT 1
yep.several peeps on here have fitted them.rdlclazy has one fitted on his for one.there is a piece on fitting in advice or general. I think you are confusing this with the Banshee coils, the OP is asking about the CDI. yes I am.very sorry.i obviously didn't read it properly.no idea on cdi sorry.
Post by seahorse83 on Aug 25, 2013 13:19:39 GMT 1
cheers fellow smokers, thought some one here would have tried it. Don't get me wrong re research or trial and error. I have infact converted a few YPVS motors and am across the many different combinations of stators and cdi cross referencing on the models . Some staters work with some CDI's and some dont etc. On one of my bikes I did use a miss matched cdi and stator that required alternate wiring. And worked a treat. Cheers again
Post by bare on Aug 26, 2013 4:07:18 GMT 1
Why? bother with a slightly improved version of a 4lo CDI?? IF going to the trouble of fitting a rotor/stator AND cdi then go for a 31k setup and get some palpable performance benefit for the time/trouble And expense.
