Post by woodentopp on Aug 23, 2013 6:38:02 GMT 1
Hi,
Question No 1 What paint is the best for standard exhausts? Do they need primer after sand blasting, if so what type?
Question No 2 What head gasket is the best? I've fitted a steel one and its leaking, I've seen other types on fleabay. Which is best?
Cheers.
Post by arrow on Aug 23, 2013 6:45:32 GMT 1
Plasticoat BBQ paint is good on the pipes, no primer required, but I had mine done here; www.camcoat.com/The genuine Yamaha head gasket is by far the best, IMO.
Post by stfocus on Aug 23, 2013 20:01:26 GMT 1
Hi pal I used pj1 or plastico BBQ paint and I use jointing compound for the head gasket and never had a problem some people will say different but it works for me hop this helps
Post by brownsauce on Aug 23, 2013 22:29:26 GMT 1
Norbo has good head gaskets, I've never had a problem , fitted it with a thin smear if sealer. And there alot cheaper than gen yam .
