Post by dave1967 on Aug 20, 2013 17:49:00 GMT 1
Cannot find the screws that hold the headlight to the headlight bowl..does anyone know what size they are and the adjuster screw at the bottom.
Cheers
Dave
Post by oldelsieboy on Aug 20, 2013 18:16:42 GMT 1
Cannot find the screws that hold the headlight to the headlight bowl..does anyone know what size they are and the adjuster screw at the bottom. Cheers Dave It is possible to obtain the length & gauge of most bolts via the part numbers. This particular items part number is 98506-05010, ignore the first five digits & the remaining five tell us that the bolts gauge is M5 & length is 10mm. Unfortunately this does not work for the rim adjuster screw. HTH OEB
Post by dave1967 on Aug 20, 2013 18:22:43 GMT 1
Ok thats great..is the adjuster screw the same size?
Post by oldelsieboy on Aug 20, 2013 18:30:23 GMT 1
Ok thats great..is the adjuster screw the same size? Do you have a parts fiche/pdf? OEB
Post by dave1967 on Aug 20, 2013 18:43:30 GMT 1
No I dont have that...just thought I should say its for an LC2..10mm looks to short.
Post by oldelsieboy on Aug 20, 2013 18:51:54 GMT 1
Post by dave1967 on Aug 20, 2013 19:48:19 GMT 1
Does anyone have a pic of an LC2 headlight bowl inside..im sure ive got something missing...getting frustrated now..lol
Post by Shytalk on Aug 20, 2013 20:47:45 GMT 1
The adjuster screws are about 2" long and something like M4 or M3 thread, I have got an old one knocking around if you need one but its not the best. The parts you need are 10X-84131-00 Screw Rim Adjuster X 2. 341-84332-60 Spring X 2 - these fit over the adjuster screws above. 98506-05012 Screw Pan Head X 2 - these secure the front to the bowl assembly.
Post by Shytalk on Aug 23, 2013 16:19:38 GMT 1
Does anyone have a pic of an LC2 headlight bowl inside..im sure ive got something missing...getting frustrated now..lol The 2 white plastic blocks are where the 2 adjuster screws fix to, there is a spring that fits over the thread that sit in between the lamp part and the rim.
Post by dave1967 on Aug 23, 2013 22:28:30 GMT 1
ive got all that..from what I can see I haven't got the wire clip that's just to left of the sticker..thats why mine slops around maybe and haven't got the bit with little lugs on holding headlight im guessing that's the retainer?
Post by Shytalk on Aug 24, 2013 8:47:21 GMT 1
I'll pop you a W clip in the post with the other bits.
Post by dave1967 on Aug 24, 2013 15:29:06 GMT 1
Thank You
