Post by foxyfeeling on Aug 18, 2013 13:28:04 GMT 1
Hi all this has no doubt been asked before , I have got to drain my gearbox oil to change the gasket on the side casing but I am unsure on the best oil to put in once I have finished the job . Cheers in advance Rob
Post by 47x on Aug 18, 2013 13:45:09 GMT 1
putoline light gear oil or anything like that,
Post by nikfubar on Aug 18, 2013 14:13:21 GMT 1
+1 that's what I use, good stuff
Post by stickymicky on Aug 18, 2013 21:17:46 GMT 1
10/30 engine oil is the right stuff any branded quality manufacturer
Post by stanlc7189 on Aug 19, 2013 0:07:20 GMT 1
Make sure it's 10/30 MOTORCYCLE engine oil. Car 10/30 is not designed for gearboxes / wet clutches.
Post by stickymicky on Aug 19, 2013 7:52:08 GMT 1
you get an oil that do not contain friction modifiers not many do .. im an lubricate sales manager
Post by tobster on Aug 22, 2013 17:29:13 GMT 1
ATF gear oil works for me
cj
Post by cj on Aug 22, 2013 19:25:04 GMT 1
you get an oil that do not contain friction modifiers not many do .. im an lubricate sales manager Any suggestions for top quality oils without friction modifiers Micky?
Post by spencerd on Aug 22, 2013 19:58:36 GMT 1
I use Motul Transoil 10W30
Post by Bozzy on Aug 22, 2013 20:56:13 GMT 1
Moral as above but expert....this year it's not getting condensate in the clear window so very happy
Post by stickymicky on Aug 23, 2013 7:47:59 GMT 1
total moto4 maxi tech 10w/30 synthetic tech,... or exol lubricates vanguard rally 10w/30 mineral oil
Post by looey on Aug 23, 2013 8:23:13 GMT 1
Or just 10w/30 mineral oil from any Motor Factors.
I use that or Motul Transoil in all our 2-stokes and never had an oil related problems or any clutch slip
Post by stickymicky on Aug 23, 2013 9:30:21 GMT 1
yes and sometimes the cheaper the better, as then it is lower older spec oil which when lcs where new it was not very hi tech oil
Post by steeley on Aug 23, 2013 12:35:49 GMT 1
last year or two I have been using a 5/30 semi synthetic oil that I also put in my Nissan micra .no problems so far .
