justyr
Post by justyr on Aug 18, 2013 8:35:58 GMT 1
Anyone with an lc pv hybrid - can you tell me where your pv servo is mounted? Not much space available! Cheers j
Post by 350wayne on Aug 18, 2013 8:56:21 GMT 1
Hi mate , mine is placed where the oil tank used to be ( I bought it like this ) which is fine if you want to run premix ....
dex46
Post by dex46 on Aug 18, 2013 9:09:31 GMT 1
Hi mate when I done this conversion years ago I made a bracket that mounted where the coil cover mount's to bolt the servo on I will be doing the same soon as building another one now that way you can run standard cable's somebody on here might have a better idea
Post by dusty350 on Aug 19, 2013 6:29:07 GMT 1
Hi, Lots of ways of doing it. I made a plate from a piece of "L" shaped steel, and had it welded in before powdercoating the frame; Cables are the right length and it all works perfectly. Dusty
Post by rich on Aug 19, 2013 12:58:59 GMT 1
Still building mine but I basically mounted mine in the same position as Dusty, except I made a U shaped bracket and came backwards off the coil cover mounts. It is very tight in there and not much room for all the switchgear connectors.
Post by jessy03 on Aug 19, 2013 17:01:12 GMT 1
There you go - that's how I done mine Jess ] ]
dex46
Post by dex46 on Aug 19, 2013 19:04:33 GMT 1
Thank's for that jess I will do mine that way as don't want to weld a bracket on as frame all powdercoated now
Post by hardhatharry on Aug 19, 2013 19:19:36 GMT 1
Mines just behind the headstock like in the pictures
justyr
Post by justyr on Aug 20, 2013 11:07:30 GMT 1
Thanks guys. I'll do mine like Jess as my frame is already done. Neat work.
Edited to add - btw whilst I'm asking, where have you chosen to put the cdi and pv control units?
higgsy
Post by higgsy on Aug 21, 2013 9:13:07 GMT 1
I mounted mine in the same place as everybody else, but used rubber lined 'P'clips off the frame tube instead, I've seen them cable tied on as well (!)
Mines a race bike so it doesn't run a battery or airbox so the electrics went in the redundant battery space, I just run an alarm battery for the PV's. The CDi would fit where the stock LC one goes and I reckon the PV controller would mount on the back of the battery box?
Post by cb250g5 on Aug 21, 2013 10:02:45 GMT 1
Cable ties - guilty as charged.
