Post by jessy03 on Aug 17, 2013 13:04:28 GMT 1
Been tinkering and thought I'd share my set up, the engine is a pv with the following mods - Abbey fast road tune V force reeds Pwk 28mm carbs - 150main, 42 pilot 2.5 turns out ( 45's needed ) N68x needles ( std kr1s) 2 from top Ramair filters Gibson blown GP pipes Compression 110psi Zeeltronic 1000-19 2000-19 3000-22.5 4000-26 5000-26 7000-23.5 8000-20.5 9000-15.5 10000-14.5 11000-13.5 Pv- 5000-0, 8500 - 100% from memory I tried JJH needles and 152 jets just could not get it to run right, it was nearly there but not quite. Might help a few of you, it works well for me. Jess
Post by copper99 on Aug 17, 2013 19:31:23 GMT 1
...and I can vouch it sure does sound sweet..
Post by seahorse83 on Aug 18, 2013 1:07:17 GMT 1
Nice one Jessy cheers for the feedback. I have a set ready to go on mine, have drilled and set the oil inlets and still looking for the N68X or N99 Needles, as i just know I will need them. My PWK's came with NAPF.
goodpw
Post by goodpw on Aug 18, 2013 10:30:27 GMT 1
A thread may already exist on here somewhere but could others share their set-ups in a similar way, it would make a great source of info.
My 31K engine is a bit of an unknown at the moment but once I've started really looking at it I will add more Engine tune ? - Presuming standard Carbs ?- Presuming standard, will check when I do the carb clean up Jets ? - Hopefully matched to the pipes, will check when I do the carb clean up Needles ? - Hopefully matched to the pipes, will check when I do the carb clean up Plugs - NGK BR8ES, fitted new by previous owner, not done a plug chop yet Pipes - Big can Allspeeds. Compression ? - Unknown. Filter - Standard box & element. Cheers. Goody
