Post by botty on Aug 12, 2013 22:39:19 GMT 1
Need a bit of help. My brain is getting frazzled. I can't decide which default to set, it's so obvious I can't see it.
Acewell dash, zeel pcdi-10v.
Quote from instructions. It displays "SPC-X.X RPM, the default value is 1.0. There are four options 1.0,2.0,3.0,and 0.5 It means the number of engine rotations per signal. For example 2.0 means the engine rotates 2 turns to output a signal.
Each plug on my bike sparks every 180 degrees, so in affect a wasted spark. So does that mean 2 signals for 1 rotation?
So is the default 0.5? Or something else?
Post by botty on Aug 13, 2013 18:35:29 GMT 1
Anyone?
Post by flames on Aug 13, 2013 18:38:41 GMT 1
that's how I would work it dude.if you set it at that,and its wrong,can you not set it accordingly?
Post by midlifecrisisrd on Aug 13, 2013 19:06:30 GMT 1
does the zeel not have a seperate one pulse per rev tacho output
steve
