Post by thehut on Aug 11, 2013 21:53:37 GMT 1
can somone tell me if this is a rd350lc marster cylinder as baught a repair kit. and the seal and shaft are bigger. measured shaft that i got and its 5/8. iv been told this is correct for the 350 twin discs. this could be why my brakes are not working unless i clamp a caliper pipe off on one side.
Post by oldelsieboy on Aug 11, 2013 22:16:03 GMT 1
can someone tell me if this is a rd350lc master cylinder as bought a repair kit and the seal and shaft are bigger. measured shaft that i got and its 5/8. iv been told this is correct for the 350 twin discs.
Thats a 14mm bore, says so on the body between the banjo bolt & the brake light switch. OEB
Post by Roofmonster on Aug 11, 2013 22:18:07 GMT 1
Blimey OEB - you have good eyesight!
Post by thehut on Aug 11, 2013 22:38:01 GMT 1
you have got good eyesight. now i know why im having problems. need to find the correct one now then. bet thats why the lad sold it on ebay. cheers
Post by Deleted on Aug 11, 2013 23:34:53 GMT 1
Fazer master cumin fees are a good upgrade
Post by Deleted on Aug 11, 2013 23:35:39 GMT 1
Bleeding I phones change what you type meant master cylinders
Post by thehut on Aug 11, 2013 23:48:18 GMT 1
ok cheers for that ill have look
Post by Norbo on Aug 12, 2013 7:43:25 GMT 1
I have just had some new 5/8 mas cylinders in they are in a 250 lc shell but 5/8 so it keeps them cheep at £40
