Post by thehut on Aug 11, 2013 16:27:35 GMT 1
anyone got any ideas why i cant get any brake pressure at the lever on my rd350lc. iv used a ltr of flued now and still got nothing. no air is comming out pipes now so cant be air in system. both brake calipers are moving so must be a bit pressure there. cant think of anything els to do.
Post by bare on Aug 11, 2013 17:03:02 GMT 1
Look into the Mastercyls' Reservoir in the floor of it there is a Very tiny hole. Be 100% sure that it is unclogged. Also try reverse bleeding: using a cheap plastic disposable syringe. Force fresh brake fluid thru the caliper's bleed nipple. Takes a bit of patience as it can be slow... BUT this works... in any undamaged system!
Post by thehut on Aug 11, 2013 17:36:06 GMT 1
theres 2 small holes in mine. ill check them. i ordered a new m cyl repair kit. but when it came it to big for some reason
Post by thehut on Aug 11, 2013 17:46:10 GMT 1
Look into the Mastercyls' Reservoir in the floor of it there is a Very tiny hole. Be 100% sure that it is unclogged. Also try reverse bleeding: using a cheap plastic disposable syringe. Force fresh brake fluid thru the caliper's bleed nipple. Takes a bit of patience as it can be slow... BUT this works... in any undamaged system! just found if i clamp one caliper off the lever ok then
