Post by calum64 on Aug 11, 2013 15:04:00 GMT 1
I'll start with the fact I cant work a computer(too old) took me hours to set this up so unless someone replys I wont know if it works.i have an rd 350 lc 1980 that's been in boxes since I stripped it 31 years ago. I would like some(quite a lot) of friendly advice on rebuilding it from scratch
Post by molegripper on Aug 11, 2013 15:07:24 GMT 1
Yes it worked and there's plenty of advice available - do you have specific questions.
Post by arrow on Aug 11, 2013 15:07:32 GMT 1
No worries dude, welcome in. If you hit the refresh button you will see any replies a lot quicker, especially useful if you are having a one to one with some one.
Post by rich on Aug 11, 2013 15:17:55 GMT 1
First thing is I hope you are restoring it for yourself as you will more likely spend 2-3 times what it will actually be worth when finished! Secondly, you are in the right place for parts. Many new parts are still available but there are numerous ebay sellers charging extortionate rates for bits you can still get from a dealer. As long as you stripped a complete bike at least you should have all the parts. Hopefully the tank is not rotten. First thing is to sort all the parts into what needs powdercoating and what needs plating and go from there. Good luck and be sure to post up plenty of pics, we like pics
Post by calum64 on Aug 11, 2013 15:26:09 GMT 1
I have 2 engines one is stamped 4lo its in a million pieces but is original engine with knackered crank. the other is a 4l1 still in one piece is it a 250 bottom end? whats the diff and can I use one as a template to copy while building original
Post by arrow on Aug 11, 2013 15:28:01 GMT 1
4L1 is a 250 engine but may have been converted to a 350. What does it say on the side of the barrels?
Post by calum64 on Aug 11, 2013 15:39:49 GMT 1
no barrels only a bottom end that I bought along with other bits and pieces 30 year ago. that's why i'm now looking at parts and wondering what they are because ive not looked at it for at least 28 years and at 49 the brain don't work to good
Post by arrow on Aug 11, 2013 15:46:34 GMT 1
Many of the 250 and 350 parts are the same, including the bottom end.
Post by rich on Aug 11, 2013 15:59:00 GMT 1
If the 4L0 cases match the frame number, I would use them as a bike with matching engine and frame numbers will always be seen as original so will be worth more.
Post by calum64 on Aug 11, 2013 16:00:44 GMT 1
myframe is painted and put back together with elec etc going to start building engine can I have advice on buying recon cranks
Post by arrow on Aug 11, 2013 16:05:59 GMT 1
Norbo the site admin does good cranks dude.
Post by oldelsieboy on Aug 11, 2013 16:20:54 GMT 1
Update your profile, or at least state where you live as there may be a kind local soul who will offer to help.
OEB
Post by calum64 on Aug 11, 2013 16:22:58 GMT 1
I think the barrels were rebored before I bought it don't know if it was by somebody that knew what they were doing or not.i live in sw Scotland can anybody recommend someone to have a look at them. don't mind driving a couple of hours
Post by arrow on Aug 11, 2013 16:26:39 GMT 1
Barrels will be 54mm bore (nominal) for the 250 and 64mm bore (nominal) for the 350. Will also say on them 4L1 and 4LO respectively as well as stating the cc for the 2 sides combined.
Post by calum64 on Aug 11, 2013 16:26:57 GMT 1
head is all chipped when rings broke can these be repaired
Post by arrow on Aug 11, 2013 16:29:09 GMT 1
head is all chipped when rings broke can these be repaired If there are no 'proud' areas should work fine. My engine has this kind of damage on the R/H side, runs great.
Post by molegripper on Aug 11, 2013 16:33:01 GMT 1
head is all chipped when rings broke can these be repaired Detonation marks are fairly common in heads. Always seems to be the RHS for some reason. Should'nt effect bike performance greatly - but a picture on here would help assess it.
Post by calum64 on Aug 11, 2013 16:36:19 GMT 1
cheers lads. when the wife or kids show me how to post pics I'll try and post some as it go's on but after 30 years don't expect it to be running this year
Post by steve h on Aug 11, 2013 18:02:33 GMT 1
Calum, you are not an idiot if you struggle with computers. I have met quite a few people who are idiots, and they did nothing else but computers! Good luck with the jigsaw, loads of info off knowledgeable folks on here.
Post by midlifecrisisrd on Aug 11, 2013 18:14:49 GMT 1
as said if the 350 bottom end numbers match then would be foolish to not try and rebuild with that one at any cost.
if it's a 1980 and you have had it 31 years then would be a rare low owner bike.
good to see another scottish lc getting rebuilt
steve
Post by calum64 on Aug 11, 2013 18:42:11 GMT 1
Only 3rd owner. Problem is i never sorn it. Only just thought about it this year but believe it could cost a fortune and everybody knows how scots dont like parting with money.
Post by 47x on Aug 11, 2013 20:20:15 GMT 1
hey callum,just box it up and sell it to me chap,lol
Post by kevsypvs on Aug 11, 2013 20:29:24 GMT 1
where in Scotland are you mate
Post by calum64 on Aug 11, 2013 21:10:23 GMT 1
I wouldnt sell it even when drunk (plenty of that over last 30 years) so no chance not. Told the mrs to order a big coffin and bury it with me
Post by Delbert on Aug 11, 2013 21:24:12 GMT 1
Only 3rd owner. Problem is i never sorn it. Only just thought about it this year but believe it could cost a fortune and everybody knows how scots dont like parting with money. Depends how long ago you took it off the road ? Mine was off the road from 1995 till 2011 and was never sorn as it didn't exist then , nothing was said when it came to life again !!
Post by calum64 on Aug 11, 2013 21:26:06 GMT 1
Im just outside dumfries a lorry driver for my sins that gets all over country so was hoping to use this forum to meet and pick peoples brains when im travelling
Post by calum64 on Aug 11, 2013 21:28:36 GMT 1
I like good news like that mine been off road since 83
Post by Deleted on Aug 11, 2013 21:31:25 GMT 1
How far is bishop Auckland from you, big meet up there next week end
Post by kevsypvs on Aug 11, 2013 21:32:13 GMT 1
im not far from you mate was at the scrappies in Dumfries on friday
Post by calum64 on Aug 11, 2013 21:40:05 GMT 1
Bish auk about 2 hours away. Going away this sat is it a2 day meet.could take a run down sunday if so
