Post by blyth1970 on Aug 9, 2013 21:49:08 GMT 1
Just fitted 350 motor into my bike, put it all back together, rode it and it slips like a bitch, dammmmmmmmmmmm guess I should have checked it first. oh well
Post by soccersmyth on Aug 9, 2013 22:47:20 GMT 1
Is it clutch slip.
Not the end of the world if it is.
As long as it runs sweet, anything else will fall into place with a bit of tinkering.
Keep the faith
Post by tygertung on Aug 10, 2013 6:02:12 GMT 1
I have found that you need to oxide blast the steels, perhaps sand paper would work, havbn't tried it, and you scrub up the fibres with a bit of scotchbrite.
Post by flames on Aug 10, 2013 8:08:49 GMT 1
what oil have you used in gearbox? I had Castrol 10w30 in mine once and had no slip at all,i had a water pump seal leak,and when I sorted it,i used some other oil I had,and mine slipped as soon as it hit the powerband.went back to Castrol 10w30,and it was fine.
Post by blyth1970 on Aug 10, 2013 22:07:53 GMT 1
iam using rock oil lite gear oil
Post by kevsypvs on Aug 10, 2013 22:14:34 GMT 1
use Castrol 10w 30 gear oil mate that's wot I use in my bikes without any bother
