Post by mattrosersv on Aug 5, 2013 9:04:57 GMT 1
Hi All, sorry second post and second question..
2UA standard jetting. Does any one know the standard jetting (mains and pilot) for 2UA carbs?
I have seen mention of 190 mains, but have also found a doc on line in Italian (I think..) that states 240s. I've chucked 250s in for now as I had them kicking around, but want to get back to standard.
Need to sort the brakes before I can send it out for a run.
Cheers,
Matt
Post by nige on Aug 5, 2013 16:56:49 GMT 1
Look in tech info. Jetting carbs . Standard jetting in that section for power jet carbs (if power jets fitted ? ). My 2ua got 31ks on it so depends on carbs.
Post by mattrosersv on Aug 6, 2013 8:33:41 GMT 1
Perhaps this should be in e carb jetting section, but since I put my first post here I hope it is OK.. Yes I have the 2UA powerjet carbs. I can't see the standard 2UA settings in tech specs so not sure if to assume they are the same as 1UA carbs or go with the the Settings I found here www.rd350lc.net/specengine2UA-3.jpg (actually appears to be 250 although my Italian/Spanish /portugese is not that good . As an aside I checked the carbs out yesterday and there is no fuel tap vacume take off. A road test will answer this, but a little way off this point at the mo (no brakes!). Cheers Matt
Post by midlifecrisisrd on Aug 6, 2013 17:06:50 GMT 1
Perhaps this should be in e carb jetting section, but since I put my first post here I hope it is OK.. Yes I have the 2UA powerjet carbs. I can't see the standard 2UA settings in tech specs so not sure if to assume they are the same as 1UA carbs or go with the the Settings I found here www.rd350lc.net/specengine2UA-3.jpg (actually appears to be 250 although my Italian/Spanish /portugese is not that good . As an aside I checked the carbs out yesterday and there is no fuel tap vacume take off. A road test will answer this, but a little way off this point at the mo (no brakes!). Cheers Matt 2UA has been referenced as a few things but is basically a 1WT or R so should have 185 mains as standard I believe. Steve
