Post by brownsauce on Aug 4, 2013 12:14:58 GMT 1
Hi guys I'm having trouble getting my clutch clear on my 250 lc , everything is new from the cable to the plates . I've currently got putoline gp10 gear oil in it. What is the best oil to try? Or as anyone got any other ideas ?
cooler
Post by cooler on Aug 4, 2013 12:25:53 GMT 1
I use ATF ...have had zero probs
Post by wallcraft on Aug 4, 2013 20:49:40 GMT 1
ATF best if you have slip issue but makes the box a little notchy when hot, worth a try.
Post by yamaha341 on Aug 5, 2013 1:31:05 GMT 1
10/40 semi syn in all my strokers boxes no fancy oil back when these were new and they worked ok back then just move up a wee notch to semi as its a bit easier to get than other oils off the shelf and works greeeeaaaat as tony says
