Post by thehut on Aug 4, 2013 11:10:06 GMT 1
does the seat lock with the key. or is lock just for the helmet holder. not sure if my lock broke. as you dont need key to remove seat. bike is lc350.
Post by oldelsieboy on Aug 4, 2013 11:12:08 GMT 1
does the seat lock with the key. or is lock just for the helmet holder. not sure if my lock broke. as you dont need key to remove seat. bike is lc350. You should need the key to remove the seat. OEB
Post by thehut on Aug 4, 2013 11:15:46 GMT 1
thaught so. my lock must be brokin then. had it to bits and can not see how it works to lock seat. might be bits missing. cheers
Post by jazzykecks on Aug 5, 2013 17:29:15 GMT 1
Check the under seat fittings first. Something maybe loose or broken to prevent lock working properly, expensive do for a lock set !!!
Post by thehut on Aug 5, 2013 19:04:39 GMT 1
fittings are ok. ill have look in the lock
Post by dodgydoughnut on Aug 5, 2013 19:05:05 GMT 1
my lock is missing from mine.just a hole.did wonder this myself
