Post by petehodges on Aug 3, 2013 10:02:13 GMT 1
Hi ya lads I,ve got a Lc with pv engine in I had a new gen 31k loom fitted last year The problem is I hate the pv clocks on it as Lc ones look & match much better so here's the thing how much hassile& stress is it too put Lc clocks back on it Without butchering my nice new loom cheers pete Also if I can put Lc clocks back on what sort off money would you expect too pay for them ?
Post by soccersmyth on Aug 3, 2013 10:27:58 GMT 1
Should be straight forward enough as both clocks use cable drives for the gauges, And have the same amount of dash lights and a temp gauge.
No idea if plug and play though, But it would be nice if it was.
LC clocks usually £100-£150
Post by midlifecrisisrd on Aug 3, 2013 15:23:06 GMT 1
as soccersmyth says it is straight forward.
either take the loom out of the lc2 clocks and fit to the lc clocks. at worst a bit of soldering especially to match up the temp gauge wiring.
Post by dusty350 on Aug 4, 2013 10:03:08 GMT 1
Hi, I have done this. 350LC with F2 engine and loom, switchgear etc. I retro fitted a tacho drive gear for the Lc clocks, and worked out how to wire the LC clocks into the F2 loom. I have the wiring details somewhere, I will try and find them for you.
Dusty
Post by petehodges on Aug 4, 2013 17:25:08 GMT 1
Hi, I have done this. 350LC with F2 engine and loom, switchgear etc. I retro fitted a tacho drive gear for the Lc clocks, and worked out how to wire the LC clocks into the F2 loom. I have the wiring details somewhere, I will try and find them for you. Dusty Dusty that would be dead handy mate as I,m going too do it myself or should say have a go at !
dex46
Post by dex46 on Aug 4, 2013 19:00:47 GMT 1
As steve said im sure its just a case of swapping clock loom over even think the temp wire's are the same best get a wiring diagram for the Lc and 31k it can't be hard mate I did this conversion back in the 80's when I really didn't have a clue what was what Lol
Post by midlifecrisisrd on Aug 4, 2013 20:45:31 GMT 1
As steve said im sure its just a case of swapping clock loom over even think the temp wire's are the same best get a wiring diagram for the Lc and 31k it can't be hard mate I did this conversion back in the 80's when I really didn't have a clue what was what Lol Thinking about it it is really easy. lc2 has nearly the same number of lamps so simply fit the idiot lamps in their correct positions and fit an illumination lamp in each clock ( 31k has 3 so may have an extra one you can clip off and insulate the wires ) and fit the distance sensor reed switch and then simply a +12v and -0v and the trigger for the temp gauge. Job done. Steve
