Post by thehut on Aug 2, 2013 19:04:12 GMT 1
just put a spare oil pump on my lc350. so I can send mine off to get oil leak fixt. but pump I put on is getting red hot I noticed when I was bleeding it. do the pumps get hot like that or is it faulty
Post by arrow on Aug 2, 2013 19:31:23 GMT 1
Hi, the pumps do get hot in use, but only once the engine is up to full operating temperature.
Post by thehut on Aug 2, 2013 20:06:45 GMT 1
this was red hot after a few mins. could not keep hand on pully to bleed it. should I of changed shaft that came with pump. il get my pump that's leaking to you soon. just don't want to be without bike wile weather good
Post by steve h on Aug 2, 2013 20:48:48 GMT 1
WAs it hotter than the casing it is fixed onto?
Post by thehut on Aug 2, 2013 20:59:49 GMT 1
yes id say so. might have to put old pump back to see if that same
Post by ianr4863 on Aug 2, 2013 21:08:45 GMT 1
Do you have the little washer on the end of the drive shaft in place ? Have you mixed a 250 shaft with a 350 pump ? Just a couple of thoughts ...
Post by Delbert on Aug 2, 2013 21:14:40 GMT 1
Does the shaft that came with that pump have the same amount of threads /turns on it as the one fitted to the bike ??
Post by thehut on Aug 3, 2013 0:04:45 GMT 1
i cant say. as baught bike. with rebuilt engine. so have not takn anything off. but can see were you comming from. think i might have to strip engine and start again. as got no faith in guy who rebuilt it now
Post by arrow on Aug 3, 2013 0:41:25 GMT 1
Don't run the bike anymore, its simply not worth it. Send me both pumps labelled up (original pump that came off the bike and spare etc) and I will sort it for you. I will know what's gone wrong as soon as I see them.
Post by dusty350 on Aug 3, 2013 8:23:23 GMT 1
Arrow is so fast he could be classed as an emergency service !! It wont be off the bike for long if you send it to him. Dusty
Post by thehut on Aug 3, 2013 10:47:24 GMT 1
ok. ill get pump sent off to you cheers
