Post by petehodges on Jul 28, 2013 23:01:08 GMT 1
hi lads i really need some help here long story cut short ive had this bike for over 13 years spent well over £7k on it ( i kid you not ! ) though the years with parts and diffrent people and still it wont start to list but a few new gen loom , new crank engine rebuilt tested stator plate & coil west country windings i cannot take it anywhere as from 1 - 10 miles it stops you will never get it too start kicking it so pushing home i go got it running saturday after 1000 kicks & shouting then pushing down the road for it too start up i then swiched it off never too start again! i,ve spent a fortune on this bike and i used too love it now i,m fooking sick of it & thinking about breaking it up for bits this bike has been pushed around my 4 different houses i lived in and is the laugh off the year with my mates i would really love too sort this lads as its done my nut in for years please any advice help welcome i think its electrics as when i took the brand new plugs out and kicked it no spark i even held the plug in my hand when kicking it ! so where do i go from here ? sorry as you can tell i,m well pissed off with it all cheers all pete
paulo
Post by paulo on Jul 28, 2013 23:26:07 GMT 1
Hi Peter, been there m8. When you say no spark at plugs have you got them earthed to a head bolt - the spark on these old girls are very weak even at there very best !. Had starting problems with my bike after being laid up for 6 months, turn out to be old petrol. So if its older than 2/3 months then ditch it and try fresh - but make sure you have some sort of spark at the plugs first!. If not it could be as simple as the kill switch or kill switch wiring plug - had an issue with mine a couple of years back - new harness but black/ white wire from the Rhs switches was badly corroded giving no spark!. Don't give up mate, where are you, someone maybe close by to help out !.
Post by petehodges on Jul 29, 2013 7:04:11 GMT 1
Cheers paulo I,m in herts not far from Stevenage yes mate I,ll ditch the fuel as its getting on cant make out how sometimes there's a spark then nothing should say when testing with plugs out I was pushing it over with my hand not by foot I,ll speak with Norbo and put a new coil on this week
paulo
Post by paulo on Jul 29, 2013 8:27:53 GMT 1
Also a good thing to check out is that you have a good earth at the coil. Some people even expose the bare frame under the coil mount to ensure a good earth. With both plugs laid out on the head, you should be able to turn it over by the kick start fast enough by hand to give you a spark !.
Post by flames on Jul 29, 2013 19:57:39 GMT 1
faulty cdi perhaps?
Post by petehodges on Jul 29, 2013 20:20:31 GMT 1
Spoke with Norbo apparently there bomb proof within reason anyway mate Ordered new coils so I can rule it out so the saga goes on
Post by midlifecrisisrd on Jul 29, 2013 20:53:50 GMT 1
29k50 cdi's can be iffy.
they will work for short periods or if you tap them.
Post by petehodges on Jul 29, 2013 21:08:29 GMT 1
29k50 cdi's can be iffy. they will work for short periods or if you tap them. Steve I'll check that out aswell cheers Steve keep it coming lads greatly appreciated
Post by kevsypvs on Jul 29, 2013 22:35:32 GMT 1
id say bad earth somewhere mate clean them all up and see whats gives
Post by 137d on Jul 29, 2013 22:45:38 GMT 1
CDI Faulty. Next time it chucks it whip the tank off and shove a plug in the cap and earth it.
Turn the engine over....no spark....tap the cdi and it will hopefully produce a spark. I have 3 cdi's with intermittent faults that work when tapped.
Good Luck.
Post by steve h on Jul 29, 2013 23:08:37 GMT 1
Sounds like it could be coil. Fingers crossed the new one cures the problem.
brads
Post by brads on Jul 30, 2013 11:35:15 GMT 1
I'm guessing CDI unit. There was a bunch of them over a certain year that were prone to faults. I've seen people fit clamps around them and this seems to work......
Post by Shytalk on Jul 30, 2013 12:26:40 GMT 1
Problem is it could be any of the above..........most likey though are the stator or CDi.
matt7
Post by matt7 on Jul 31, 2013 18:08:12 GMT 1
Ignition switch ? ...
Post by Yogi on Jul 31, 2013 20:19:47 GMT 1
Check the multiplug from the ignition , I cleaned mine twice an still had probs , ended up cutting the plugs off an joining the wires ,no more probs, worth a quick look
Post by petehodges on Aug 3, 2013 16:37:29 GMT 1
More pushing up &down the road today just had a load of backfiring going on I think it's time too look at cdi
Post by matstar on Nov 12, 2013 19:29:19 GMT 1
Hi PeteHodges, Any development/update on this issue? As mentioned in prev posts.. maybe check earth points/corrosion/ignition sw /loom non continuity/etc... Also reside in SG1 area, so maybe able 2 help...? M@
