Post by kevsypvs on Jul 21, 2013 13:03:44 GMT 1
having a bit of a night mare getting usd forks for my ypvs 350 will gsxr k6 lo forks fit , whats the other options on usd forks for the f2 350 ypvs id like to use std yokes at 35mm if possible
Post by kevsypvs on Jul 21, 2013 13:57:14 GMT 1
thanks mate thinking of gsxr 600 k6 forks
Post by oldelsieboy on Jul 21, 2013 14:44:39 GMT 1
Post by kevsypvs on Jul 21, 2013 15:20:35 GMT 1
do you know the od of these mate?
Post by rich on Jul 21, 2013 15:44:12 GMT 1
I'd be looking for a complete front end. Worst case is then a stem swap, rather than trying to get forks to fit the yokes you have. As above, there's no way any USD forks will fit the standard 35mm yokes.
Post by oldelsieboy on Jul 21, 2013 16:01:27 GMT 1
do you know the od of these mate? IIRC they are 43mm & 41mm at the waisted section. The yokes only require a 5mm spacer under the bottom bearing to fit. OEB
Post by nikfubar on Jul 21, 2013 16:08:59 GMT 1
I got GSXR600 K4 forks on mine easy fit just needed new taper bearings & make some lock stops
Post by kevsypvs on Jul 21, 2013 16:14:38 GMT 1
I got GSXR600 K4 forks on mine easy fit just needed new taper bearings & make some lock stops yep I like the look of them mate take it you just used the yokes off the gsxr600 as well
Post by nikfubar on Jul 21, 2013 17:45:19 GMT 1
Post by kevsypvs on Jul 21, 2013 17:53:42 GMT 1
looks shit hot mate ,il have a look see what I can find ,thanks for the info
