Post by windymiller929 on Jul 20, 2013 13:42:07 GMT 1
hi, just rebuilt my engine and have bled the oil pump as described and fitted new clear oil pipes. when following the workshop manual for start up following a full rebuild I have insured I hold the oil pump cable so that the pump is at max to get the oil to the carbs as soon as poss whilst gently blipping the throttle,.however I have noticed that the oil moves up the right oil pipe painfully slow and the one supplying the far/left carb seems even worse. I have used a different two stroke oil to before but it is a quality one and the system bled. is my pump knackered?
Post by Taylormade on Jul 20, 2013 13:49:14 GMT 1
Remove the pump and send it to Arrow (on this forum), he will strip it, check it and rebuild it! It will come back like new! I've had mine done and I'm sure others will comment on how good arrow is! Don't risk a rebuilt engine with a non rebuilt pump.......
Post by flames on Jul 20, 2013 13:57:47 GMT 1
i agree with taylor made.send it to arrow,it will come back better than new,and he can set it to flow a little more if you require,as oil has improved greatly since these bikes were first built.fantastic service worth every single penny.
Post by arrow on Jul 20, 2013 13:57:57 GMT 1
The oil should hit the carbs within about a minute, as said don't risk damaging a new motor with a 30 year old pump.
Post by windymiller929 on Jul 20, 2013 14:04:32 GMT 1
thanks for the advice I have sent arrow a message or if anyone has his contact details let me know. thanks again
Post by arrow on Jul 20, 2013 14:10:00 GMT 1
You had the carbs cleaned on this bike dude?
Post by steeley on Jul 21, 2013 6:16:09 GMT 1
as the other guys said get the pump serviced by arrow .also check the oil feed passage way in the carbs .
Post by copper99 on Jul 22, 2013 15:22:12 GMT 1
I also read on this site about priming the oil lines with a syringe, seems to make sense to me, so i did this as well with mine. [a href=" |http://thumbsnap.com/KER6JSzc"] |http://thumbsnap.com/KER6JSzc[/a]
Post by butchers on Jul 23, 2013 21:24:02 GMT 1
