Post by yamanastic on Jul 19, 2013 23:18:15 GMT 1
I'm thinking of replacing the carb main nozzle and needles in my carbs, so looking for a bit of advice, 1 is this a good idea 2 if it is a good idea how do I remove the main nozzles from the carbs 3 are the main nozzles from yambits any good or am I better using genuine nozzles 4 as the needles are no longer available what make of needle is good to use
paulo
Post by paulo on Jul 20, 2013 0:21:22 GMT 1
Like everything they do wear, so replacing with new is a good starting point. Yambits is a big NO, ring Allensperformance for gen parts - all you need is the jet needle and needle jet numbers for your type of carbs - approx £45 posted (both carbs). Loosen of main jet a few threads and tap lightly with a small hammer to release needle jet. Remove main jet and needle jet pushes up through the top of the carb - slides removed. If renewing and very tight a thin punch will help tap them all the way out.
Post by yamanastic on Jul 20, 2013 0:36:34 GMT 1
Thanks for the reply and advice, I know the needle is a 5k1 do you know what the number for the main nozzle would be?
paulo
Post by paulo on Jul 20, 2013 0:44:24 GMT 1
From engine numbers 4LO 100101 onwards:- Jet Needle - 5K1 Needle Jet - P-2 (345)
Post by yamanastic on Jul 20, 2013 0:56:58 GMT 1
Thanks paulo that's great
