Post by Bozzy on Jul 18, 2013 23:44:52 GMT 1
Took carb off and packing up decided to put slide with needle into carb for safe keeping!!......well forgot picked it up and yes the bloody thing slide out and dropped onto the floor slide and needle attached. Got carpet down so not sure if it helped. Had a good look can't see any bend spun it in hand etc and can't see any movement. When back in the slide I thought I could see bend but appeared to be visual effect. Put the lot back into carb and with a little shake it has slid into place and moves freely looking down the carb needle appears to be straight..... Think I have got away with it ? One question the slides do appear to have a little movement side to side in the carb. Wondering if they are worn...but where you get new ones ? Trouble having a pv with 28k on clock
Post by flames on Jul 19, 2013 8:28:08 GMT 1
did you try rolling slide on a flat surface? mine has a slight bend in it,but if i spin it between my fingers,you cant tell.when i roll it on a flat surface pointy end down,i can see the clip end wiggle a bit. dont know about the slides,wouldnt want too much movement,but at same time,think it would need a little give to allow it to slide freely?
